that looks great, good luck
Nice work mooch, isn't it a nice feeling knowing that now when you run something over it won't end up in the car with you.
dang dude, that ain't bad work!
K |
Good clean job there.
Looks good. No more wet feet and/or other body parts. The SwissMiss Chocolate sound deadener is a unique innovation.
Thanks guys. I took the advice of a good friend and decided to use the rubber stuff on the inside and outside of the pans. I figured when I have the insulation and carpet in, I won't ever want to mess with it again. Since it had some time to dry, I want to spray some WD-40 in and see how it runs off. As long as liquid makes its way to the drain holes, I'm good to go.
Man this thing has taken me a heck of a lot longer than I thought. I figured it would be easy, but once I got the old pans out, there was just sooooooooo much surface rust to grind down and treat. This car is BARELY able to restore without taking it down to the frame. MoocH |
Aint this Hobby fun?
Just think, some guys buy a car to take it all apart and rebuild it better than new?? I just want to make mine driveable...paint on the surfaces that need paint and chrome where it belongs. I really like the Rat Rods!
Tazz Rat Rods Rule! |
Re: Aint this Hobby fun?
mooch, how long did the installation take?
I started in early July. If you check out my album, I finished the cutting around 7/24 and started treating the frame rails. I figured it would be a good time to weld in some 1/4in steel bars to stiffen up the rusted areas inside the frame rails.
Remember, I only get to work on this thing on the weekends, so I average about 12 hrs a weekend wtih sat and sun. I still have to prime and rubberize the passenger side before I lay down the insulation. The mats are just sitting on my trunk waiting to be layed in. hopefully I can get everything back in and my fuel lines connected and try it out again before the snow comes. MoocH |
| Recent Hotrodders' Lounge posts with photos |
