I Got A Shop - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-13-2004, 06:48 PM
fat50's Avatar
Kenneth Howard hates me...
Last journal entry: Engine mock up
I would have a door to get into the storage from inside the shop.
And being from Detroit, I would get rid of the door in the alley and the skylights, Thats just easy access for an "out of the way" building.
Chris
  #17 (permalink)
Old 04-13-2004, 11:24 PM
Im trying to have an idea!
well i prefer the storage section to be separate. that will contain non automotive stuff in there. The security issue should not be a problem. there is a bike shop about 2 blocks down, he said that he has never had a problem with thievery. he also said that sometimes he leaves the back door open by accident and never had a problem. i will also talk to the Brinks guys next door and see if i can get a direct connect to them . about two streets over is 4 lane "freeway" and there are alway cops using that road because the police station is about 4 blocks down. so i hope ill have no problem with that kinda stuff..
  #18 (permalink)
Old 04-14-2004, 06:29 PM
BigMac's Avatar
1949 Chevy Truck
MRGM,
I grew up around Abilene and down there all the time. Great place to live and plenty of buildings to build a nice shop without code enforcement going after you. I would still check in case you want to ever build a paint booth or anything like that.
I always check code enforcement and zoning before I buy property anywhere. Better safe than sorry. Also at 5000 sq ft. , you might have a problem with Fire Marshall unless you have sprinklers.
Now is the time to check all this out not when you are going after a C.O.
  #19 (permalink)
Old 04-14-2004, 07:13 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
My old neighbor built houses etc., he said sometimes it's easier to go ahead and build to code without a permit and pay the fines later. He didn't do that personally as it could get his license revoked, but he suggested that to a few of the neighbors and a few never did get fined. I guess living out in the boonies it's easier to get away with. Living in the boonies doesn't always mean it's easy to get a permit, as that was the case where I used to live in the suburbs of Phoenix.
  #20 (permalink)
Old 04-14-2004, 07:35 PM
BigMac's Avatar
1949 Chevy Truck
Just don't spend alot of money on your shop to find out later that the city will not let you have any utilities turned on without spending another 50k
  #21 (permalink)
Old 04-15-2004, 12:28 AM
i have the electric utilities there. and being in the line of work i am in, i know what to do about the codes. the thing about Abilene is you will have to update the building only if you spend so much or renovate so many sq ft or will be considering the building a public place. i will just get diff permits at different times. and kinda helps if ya know the local code guy . also on somethings it will be cheaper to pay the fines then to do it the "right" way, then there are things they can make you change to to the "right" way and end up being stuck. if all else fails i will get a small trailer, park it up front and get it rezones to a residential area, (it used to be zones as a residence) then call the building a storage building and that will be that. hopefully .
I can have the water and sewer brought to the property line (if needed) without the city looking at the building. then i can do the rest to the building myself. easy work.
i can always get around the city-problem will be getting my a** in gear
