i got the upgrade 4L60e sunshell, but no thrust washer.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2011, 10:15 AM
old yukon's Avatar
I went to install my new sunshell and found out that there was no new thrust washer for it.
I cant return the part, no return policy Bla Bla,bla...
What can i do now.
The washer kit came with a black plastic washer with 4 tab that is a bit undersized, but this is for the OEM not the beast.
how important is this beast sunshell thrust washer? can i get it separately for somewhere?
Old 04-11-2011, 11:41 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
Call monster transmission 800 708 0087 & ask for one.
Are you sure the black plastic washer isn't the correct one,
That's the description of the washer that's supposed to be the replacement.
Rich
Old 04-11-2011, 12:05 PM
old yukon's Avatar
thanks for that Richard
The black plastic washer i have in pack has four vertical tabs that seat between the tabs on the roller race of the low and reverse clutch, not the 3 round tabs on the thrust washer for the beast.
I was thinking of cutting the tabs of and sanding back the center of the 4 tab OEM plastic thrust washer, as a last alternative.
Is this washer so important?
Old 04-11-2011, 12:18 PM
I called monster for you.
The part is $4. & shipping is $9
Rich
Old 04-11-2011, 12:28 PM
old yukon's Avatar
Thanks Richard your a great help !
Old 04-11-2011, 07:22 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Correct thrust washer must be used... do not use the original washer too, only 1 washer is used
Lower reverse clutch race and new sunshell, is a mod needed old yukon Transmission - Rearend 8 04-11-2011 07:21 PM
2000 4L60E to an earlier 4L60E, What do I need to change out aquaterrarv Transmission - Rearend 2 04-08-2010 06:22 PM
SBC cam thrust washer?? sexypizzaman Engine 3 02-01-2008 04:29 PM
water based washer solvent for parts washer 62CHEVYC10 Garage - Tools 31 02-03-2007 06:09 AM
Thrust washer fell out. 454me Transmission - Rearend 1 05-21-2005 08:25 PM
