I really like that style wheel, glad you could make them work the way you wanted
pin drives ?
Were those originally pin drive wheels with a center knock off like My Jag with wire wheels had.? Usually its better not to modify the wheels , go to a good parts store and buy longer lug studs. I had to replace the studs on one of my trailers and they had all the spec's in a catalog, stud thread size, length, knurl dia, and length. the knock offs usually had a lot of material in the center so yours look ok, I.ve had to find longer closed end lug nuts to run some aluminum wheels.. I think thelug nuts were off a Mustang II with the factory aluminum wheels.
The wingnuts are just for looks.
Why not just get longer studs. The holes will affect the strength especially that close to the wheel studs
Artificial Intelligence is no match for Natural Stupidity Chet |
![]() In my opinion ... you have weakened the rims and I would not use them
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
Halibrand sells lug nuts with the longer shank.
I recently bought a set of 20 for about 30 dollars ... freight included to my door. Took about 1 week from ordering to delivery. .
No stud going into the hex portion isn't a concern. The number of threads into the nut is what's important, so going to a longer shank on the nut will solve the problem without modifying some really nice Halibrands.
The damage is done as far as Y'all are concerned. The problem is fixed as far as I'm concerned. |
lug nuts
Great pix.
I have a set of MAGNESIUM Halibrands and Americans....very black, from the fifties. Not the kidney beans like yours. I run newer aluminum Halibrands on our '33 Sedan Delivery. I always find the longer shank nut. You did a nice job, however. Keep kroozen, Jim |
| Recent Hotrodders' Lounge posts with photos |
| If it has Halibrand wheels, it must be a nice hot rod...right? | Flipper_1938 | Hotrodders' Lounge | 15 | 01-01-2012 11:40 AM |
| Halibrand wheels... going away? | Motochris | Suspension - Brakes - Steering | 13 | 07-26-2011 05:08 PM |
| Halibrand wheels | 57halfton | General Rodding Tech | 7 | 10-20-2008 07:02 PM |
| Halibrand Wheels | 57halfton | Hotrodding Basics | 4 | 07-23-2008 06:08 PM |
| halibrand magnesium wheels | sparkybr74mr | Hotrodding Basics | 1 | 12-20-2005 09:55 PM |
