I have a 350 crate engine i want to make atleast 400 hp. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-25-2010, 02:57 PM
automotive breath's Avatar
Bogie, are you saying use the heads thats on it and only change the cam, carb.
& headers; and this will net 400 HP, 140 over stock?
  #17 (permalink)
Old 03-25-2010, 03:00 PM
Originally Posted by ap72
I think the dish volume is between 12 and 15cc's, I'm not sure of which,
either way it should be measured.
I don't know for sure, your right measure to be sure. The biggest fear with
this combination is detonation, the cast pistons can't take much. That's why
I recommend keeping the compression ratio low.
  #18 (permalink)
Old 03-25-2010, 03:20 PM
malc's Avatar
Living At The Speed Of Life
Bogie, No brainer, stick a Comp XE268 in there put a 750 Holley on it, due a tune up and stand back.
Which Comp 268, one of these or this one ?
  #19 (permalink)
Old 03-25-2010, 10:41 PM
Your budget ~ $1400
If your on that kind of budget get your block bored over ask for specs and buy a STROKER KIT from ebay for around $899 and up! you'll be easily a little over 400hp man!!
  #20 (permalink)
Old 03-25-2010, 11:24 PM
Originally Posted by 355Nova
...get your block bored over ask for specs and buy a STROKER KIT from ebay
Doesn't leave any $$ for heads, cam, rocker arms and push rods.
  #21 (permalink)
Old 03-26-2010, 12:44 AM
chevydragster83's Avatar
the $1400 isnt all I plan on spending on the engine that's just all I can spend now. I am willing to spend more for a good set of heads and wait a while about installing them so I can get everything else. I really like the looks of the pro-filer 195cc heads and I have heard alot of good about them. I know with the stock pistons I might not completely reach my goal but what I'm asking would the 195cc/64cc heads cause any problems untill I can upgrade the rotating assembly? I dont care about gas mileage. like I said its just going to be a weekend toy. and I want heads that are capable of more in the futer rather than getting more power now and thats it.
  #22 (permalink)
Old 03-26-2010, 12:56 AM
Sounds good!
Do the heads you want and then work around them.
build it as you buy it piece by piece. I do this alot. Make sure you got in mind what you want out of it though. By this I mean fast take off, or capable to run Nitro, or just a driver with around 350hp and up?
Do your research some more after you decide on heads and good luck bro!
  #23 (permalink)
Old 03-26-2010, 01:37 AM
Nice heads, besides from being lazy at low RPM on a stock short block, it won't
hurt to run them till you upgrade the bottom end. How much those heads cost?
  #24 (permalink)
Old 03-26-2010, 10:21 AM
there about $1000 for the set. do you think there to lazy for just a 5500 RPM engine? untill I can get it winding more? I guess I'm trying to say will they still give me a big gain over the stock heads?
  #25 (permalink)
Old 03-26-2010, 10:27 AM
my87Z's Avatar
Veteran/Firefighter-Paramedic
they will give you a world of difference from the stock heads. you wont loose too much down low (it may be a little soggier than a set of 170-180's). i've never heard bad things about pro-filer, most has be good, so i wont try and sway you away from them. if you get the heads though i wouldn't put them on till you have a different cam and valvetrain to go with them otherwise they will be really soggy.
  #26 (permalink)
Old 03-26-2010, 02:04 PM
Originally Posted by my87Z
they will give you a world of difference from the stock heads...
I agree and because of the low compression go with a relatively small cam,
something like bogie recommended to help avoid poor power at low RPM.
Also go with a thin head gasket to get the compression up and keep the piston
to head clearance ~ 0.040".
  #27 (permalink)
Old 03-26-2010, 04:38 PM
ok thats about what I figured. Like I said I want something capable of more later. Would I be better off in the long run to get the 210cc or will the 195cc be better for what I have now and still get me where I want to be later on down the road?
  #28 (permalink)
Old 03-26-2010, 04:45 PM
Would I be better off in the long run to get the 210cc or will the 195cc...
The 195 cc heads you are looking at are good for over 550HP
in excess of 7500 RPM on a good 350 CI short block. Bigger is not
always better.
  #29 (permalink)
Old 03-26-2010, 04:58 PM
This car has run 10.60's at 126 MPH with a set of ported Edelbrock performer
heads. 355 CI 11:1 compression flat top pistons, Isky 547-A flat tappet cam,
T350 transmission w a 8" converter and a 456 gear in the rear end.
If you plan on going much faster than this or plan on a big CI engine in a light
weight < 2500 LBS car, get the bigger heads.
  #30 (permalink)
Old 03-26-2010, 05:14 PM
well the engine is in a 1983 chevy silverado weighs bout 3400LB. and thats plenty fast for me lol
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
350 Crate Engine: Loud humming sound after engine warms up sofa1515 Engine 2 01-11-2010 06:48 PM
Where to buy a ZZ4 350 Crate Engine Calgary? SmokeShow01 Engine 9 05-27-2009 10:41 PM
Help with SBC 350 Crate engine ID / Specs & more 5_speed Engine 16 12-26-2008 03:58 PM
400 smb wanting to make around 300 - 350 hp 400smb_s10 Engine 5 03-25-2007 03:02 PM
