Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I have a 350T tranny with no forward gears but I have reverse
Old 07-20-2009, 08:34 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by mudking383
Hello I put a used 350T tranny in a jeep with a 355 chevy small block, but now I do not have any forward gears but I do have reverse. Could anyone give me an idea of what the problem is? thank you
If the shift linkage is operating correctly
the problem is your forward clutch IF there is no forward gears in any shifter position : " D , 2 or 1"
Since reverse functions , that tells me the trans has :
Main line Pressure.. enough to operate the trans
power transfer from the converter
