I have a 351W small block 4v - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2004, 12:54 PM
daves1969mach's Avatar
New Member
What is the best set up to run 13s? The more opinions the better.
Thank you
im putting it into a 1969 mach 1, so the car is about about 3425 pounds. and 3.25 gears, and a T-10 four speed
Old 08-03-2004, 03:44 PM
A mild hyd cam, headers, a good aluminum intake and pocket ported/port matched heads and you should be there. Aftermarket or GT-40 heads if you can afford them. A little more gear, such as 4.11's would be helpfull with the 4 speed.
Old 08-03-2004, 03:49 PM
New Member
yeah i have 411's also and a performer intake and a carter625cfm carb
also my block holes are alot smaller than my header holes, and the windsor came with 10.7 compression.
Old 08-03-2004, 04:44 PM
It doesn't hurt for the header flange to be larger than the port. Those heads can use a full port job but it takes so much time that new heads are cheaper unless you're porting them yourself. That's a hero or zero move. If you're experienced in porting go for it. If you have the time. If this is your first set get some one to donate a cracked set of heads any engine and try them first.
Old 08-08-2004, 09:57 PM
comet boy's Avatar
When all else fails burn it
Last journal entry: more hiding stuff
This might be more than you want but maybe a 392, 408, 427 stroker.
Old 08-28-2004, 09:57 PM
detroitdinosaur's Avatar
351 smallblock?
isn't that a ford engine didn't know they made smallblocks????
