I have 461 bouble hump heads need brackets - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2008, 02:54 PM
I have a set of 461's and need brackets to run alternator and power steering. can anyone help me?
Old 12-29-2008, 02:59 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
If they're in good shape then sell them and buy a set with the holes in them. Maybe a set of Vortecs or a budget aftermarket head.
Doesn't the power steering pump mount to the front of the block, not the heads?
Old 12-29-2008, 03:13 PM
prostreet6t9's Avatar
Differential/Driveline
Check here for the alt bracket. http://www.powermastermotorsports.com/bracket_kits.html
You can mount the alt on the lower pass side. Then there is a OEM power steering bracket that bolts to the drivers side,the top bracket bolts to the front header bolt. Sorry I can't remember what year its off of. Just search the bone yards and look for the bracket that goes to the front header bolt.
Old 12-29-2008, 05:18 PM
Alan Grove makes them. You tell him what heads, motor, and what you want to turn etc and he will fill your order.
Old 12-29-2008, 05:24 PM
coldknock's Avatar
I'll second http://www.alangrovecomponents.com/ .
Their stuff is top notch, and affordable.
Larry
Old 12-29-2008, 05:27 PM
302 Z28's Avatar
Sell them and find some 186, or 187 castings.
3927186....69-70...302/350......Camel hump,64cc chambers,accessory holes
3927187....69-70...350..........Camel hump,64cc chambers,accessory holes
They were not all 2.02" intake valve heads, most were 1.94" intake.
Vince
Old 12-30-2008, 02:02 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
This set will mount the alternator on a long water pump, with no holes in the head.
Old 12-30-2008, 06:33 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
I am always amazed when someone starts a thread that is identical to one that was just started a few hours ago. There is a thread that was started called "202 heads, no assecory hole...what to do?" at 10:04 which is 5 hours before this one was started.
How about doing your own research or reading the other thread before you clutter this forum with repetitive threads?
double hump heads chevy350cutlass Engine 8 11-03-2008 08:36 AM
help please!! double hump heads DB fusmc Engine 10 06-17-2007 04:33 PM
461 heads brodie Engine 2 01-29-2004 05:14 AM
Double hump accesory brackets Vander23 Engine 2 03-24-2003 02:02 PM
old double hump heads chale24088 Engine 8 06-20-2002 12:37 PM
