I have A 700R4 tranny not shifting out of 1st ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2012, 07:04 PM
Hi everybody i need a little help here is the info i have a 1983 chevy silvrado with a chevy 350 and a 700R4 tranny it is 4 wheel drive . here is my problem it will not shift out of first gear even with WOT i have read some post on here trying to figure out the problem but i am stuck i have the valve body out and i have checked the valves and they all seem to move freely the fluid looks brown and i dont know what the residue is on the bottom of the pan ? it has 1st gear, reverse,and neutral, im hopeing some on can help me out ? also how the heck do you take the valves out of the valve body ?
could the residue be a burn cluch?
Also i bought the truck this way the guy told me he was going to a friends house and when he trid to leave it whould not shift out of First gear.
thank you for your time
[IMG][/IMG][IMG][/IMG]
Old 10-04-2012, 07:08 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Welcome to Hotrodders.
I edited the thread title. I removed "Help!" as that is not needed in thread titles here. The membership folks are quite helpful
Have you checked the governor on this trans? It is under the round steel press on cover near the back of the main trans case.
there is a plastic drive gear and often this gear wears out, breaks off.
Old 10-04-2012, 07:42 PM
yes crosley i have checked the govener gear and the little valve in side moves and the gear is fine not striped or anything
1st time rebuilding a 90 model 700R4 tranny Johnnyasa Transmission - Rearend 1 06-28-2011 08:50 PM
700r4 not shifting out of 1st gear metalhead2910 Transmission - Rearend 1 08-09-2008 03:16 PM
700r4 tranny not shifting out of 1st dmd02769 Transmission - Rearend 3 09-21-2006 10:45 PM
700R4 tranny shifting questions cares Transmission - Rearend 3 05-22-2006 10:42 PM
700r4 not shifting out of 1st gear AKGMC Transmission - Rearend 2 06-08-2003 05:27 PM
