i have a 93 c/k1500 with issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2011, 12:22 PM
this is why i am stumped its got to be electrical my truck runs it shuts off some times with in twenty min at a idle or you can take it for a drive and it not shut off till you stap at a light it does this random and every time you can start it right back up the oil pressure drops slowly at a light but no eng noises and it dont madder if its in two of fwd and does it when it wants to please help
Old 04-11-2011, 08:08 PM
mean s15
Wow 20 views and no replies! well I had a 89 full-size and it did that and it was the my computer. Is your engine light on?
Old 04-12-2011, 03:50 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
An oil pressure switch closes a circuit when the pressure increases (engine running) thus powering the fuel pump.
If this switch is not working correctly or the engine pressure is very low due to wear or a bad oil pump the fuel pump will shut off, stopping the engine.
This is a safety feature so that the fuel pump will not run unless the engine is running or there is loss of oil pressure.
The oil pressure switch can be temporarily by-passed to test this but it should be repaired correctly.
vicroc
Old 04-12-2011, 04:08 PM
Race The Truck
Last journal entry: Son's Truck
It could be a lot of things ground wires and so on! This site is good for help www.fullsizechevy.com Also if your going to keep the truck I would invest in the shop manual off of ebay I did save me a lot of time to help you trouble and fix your truck. Its just a guess game with out them!
Craig
91 k1500 350 tbi gabes91 Engine 3 02-21-2011 10:48 AM
1989 K1500 z-71 k1500z71_1989 Transmission - Rearend 1 04-14-2010 07:38 AM
S10 headers in a K1500? 1meancuda Engine 3 08-05-2009 07:21 AM
92 chev k1500 4x4 budnick Suspension - Brakes - Steering 1 04-04-2008 01:38 PM
94 k1500 gears? backyard71nova Transmission - Rearend 2 10-17-2007 02:54 PM
