I have been selfish. Havn't been sharing the GTO Project Pics! - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2011, 06:45 PM
Last journal entry:
I did this a little over a year ago. I figured I could amuse some of you hot-rodder guys who are on break. I always look at the site, but never can find any ways to contribute, so for your amusement.... Your looking at the rear wheel housing drivers side on a 1965 Pontiac GTO.
ID:	52096   Click image for larger version
ID:	52097   Click image for larger version
ID:	52098   Click image for larger version
ID:	52099   Click image for larger version
Old 01-30-2011, 06:48 PM
Last journal entry:
And some more pictures for ya!
It may not be proper but it gets the job done. The surface looks rougher than it actually is in the pictures. In reality its very, very close to its original shape. All made with flat sheet metal, tin snips, hammers and a small mig welder.
ID:	52101   Click image for larger version
ID:	52102   Click image for larger version
ID:	52103   Click image for larger version
ID:	52104   Click image for larger version
Old 02-12-2011, 09:45 AM
deadbodyman's Avatar
Wiki Edits: 11
Looks pretty darn good..Fun ,isnt it? keep us posted ,build pics are always cool
Old 02-13-2011, 11:05 AM
Last journal entry:
In that case, here is the top right corner getting fabricated. It seems like everything needs to get replaced on this car. At least I have the contour still.
ID:	52653   Click image for larger version
ID:	52654   Click image for larger version
ID:	52655   Click image for larger version
ID:	52656   Click image for larger version
Old 02-13-2011, 04:46 PM
Last journal entry:
I wish I had taken more pictures in between, but hey! You just have to get her done...
This is passenger side, rear wheel, door side.
ID:	52682   Click image for larger version
ID:	52683   Click image for larger version
ID:	52684   Click image for larger version
ID:	52685   Click image for larger version
Old 02-18-2011, 11:41 AM
Wiki Edits: 11
Thats not in THAT bad a shape.looks like you got the welding down too.I just finished a 69 camero and the whole rear window was rotted out,inside too just be sure to fit your all your trim pieces before you weld so you get a good fit when your done.just use some masking tape to hold the moldings on. Once the cars all painted and your putting the trim on is a bad time to find out they dont fit any more...been there...
Old 02-18-2011, 04:03 PM
Last journal entry:
Very true about the trim. Some of the hardest parts are trying to re-create a specific shape. Even the areas you can't see, for an instance behind the rear wheel right under the lip was a nice cozy little nook for dirt, rocks and water to sit. I went ahead and created a spoon like shape so it had somewhere to run to.
The replacement panels are a close fit, however not perfect. They are better than what I can create though! Lots of measuring side to side, up down and around to make both sides equal. My worst nightmare is to have a lower quarter panel sticking out farther than the other side.
At least now I get a chance to re-do all the design flaws of that day. Also with much head scratching, the drip rails are coming off. It will be modified to still function as a water run-off, but will be smooth as a babies bottom. When I'm done with her it will surely be custom... but the same car. I had to hold back from wanting to tub the back wheels and redesign the frame. I have enough to do before its road worthy.
Half the body mounts didn't even exist anymore, or broke off upon removal.
ID:	52815   Click image for larger version
ID:	52816   Click image for larger version
Old 02-18-2011, 04:08 PM
Last journal entry:
A few more pictures
ID:	52818   Click image for larger version
ID:	52819   Click image for larger version
ID:	52820   Click image for larger version
ID:	52821   Click image for larger version
Old 02-18-2011, 04:14 PM
Last journal entry:
Might as well add a few more.
Car on hand-made jigsaws... when you can't afford a rotisserie.
ID:	52823   Click image for larger version
ID:	52824   Click image for larger version
ID:	52825   Click image for larger version
ID:	52826   Click image for larger version
Old 02-19-2011, 02:53 AM
Wiki Edits: 11
Half the body mounts didn't even exist anymore, or broke off upon removal.[/QUOTE]
Just remember how old that car is, its all normal for its age, heck over here the steel outriggers or the frame is usually rotted too...that car is nice ...I was talking to a guy in Fla last week about restoring his 65 GTO...I've done a lot of restos but never a 65 gto. If he brings it up I might have a few questions for you...
Old 02-19-2011, 12:46 PM
Last journal entry:
Feel free deadbodyman. I will be as helpful as I can be. I'm not sure how much I know until questions are asked.
Old 02-19-2011, 12:54 PM
Last journal entry:
Personally if the car was any more rotted out, I never would have done this. Its beyond me to virtually create a whole car from scratch... at least for now. I give props to those able to do so. Even more if they can do it within a reasonable time frame.
Lucky for this girl she hid a lot of damage from me before I started, so she got away with it... funny how that works out.
Edit: Now thinking about it, I may have refused to acknowledge it. :x
Old 02-19-2011, 03:16 PM
Wiki Edits: 11
reminds me of a girl I met in the winter ,upstate NY,real cute but when we got inside and she took all that heavy winter stuff off I wanted to run.decided it was too cold out and stayed ...Glad I did ,wasn't so bad afterall
It'll be worth it...
Old 02-19-2011, 10:10 PM
Last journal entry:
Nice.
sharing some pics from 2009 Kustom Roundup spi360 Hotrodders' Lounge 0 05-01-2009 03:58 PM
Sorry I havn't visited hotrodders for 4 months Jeff Nicholls Introduce Yourself 1 11-25-2006 06:07 PM
S10 Project pics!!! Weimer Hotrodders' Lounge 6 05-26-2005 08:20 PM
Project pics Pony Hotrodders' Lounge 3 10-17-2003 05:25 AM
I havn't mentioned this before, but... Halloweenking Hotrodders' Lounge 6 05-17-2002 03:15 PM
