I have never done this myself. I have put small journal 327 cranks in 283 blocks, but I'm not sure if you will have enough clearance in a 283 for a 3.48 inch stroke. You will definitely have to get out the grinder to make it clear.
a 283 block with a small journal 327 3.25" crank would make a 306
and a 327 small journal block with a 283 3" crank would make the famous 302.
you could make two interesting engines from to normal engines.
has anybody ever tried a 306? it would probly be a little more torquey than a 283. but it would probly be a waist of a good 327 unless u just had a 327 or 307 crank lying around.
never mind, that would just make a 307, i forgot to round up.
i dont think i would trust bearing spacers. it would definately be a wast if you had a large journal real 302 crank, but if u used a 283 crank with bigger spacers, it wouldn't be such a loss.
That's cute...I just had to giggle about my own youth when I would dream up possible CID combinations only to realize they already existed! My dumbest statement was telling someone I was torn between putting either a blower or a supercharger on my engine!!! DOH!!!!
Hey, Black86 I was just in Harrisburg last night....
Maybe I'll see you at a car show some time!
hahaah yeah, i work in the auto parts business so i have a lot of free time to look up parts for my own stuff and think up combinations, hahaha, and some of them are quite dumb
anyone in the PA area goin to the motorama this weekend?
thanks again guys
and about the bearing spacers, no way, definately not a fan of them, i just dont see them as being a part that would hold up, or be smart to use
1971 307 Chevy Block punched .030 overgives you a bore of 3.905, forged 350 crankshaft standard 3.48 stroke and the counterweights milled for piston skirt clearance, standard 5.7" length rods, deck clearance is the only problem. Mill the tops of the pistons to create a semi popup design. you wind up with a 333 cid small block.
(Make sure the corrected pistons are milled a little more than 0 deck height, or they WILL hit the heads. I learned the hard way with this build)
No, a 350 crank in a 305 would be a 305. 3.48 inch stroke for both motors.
K
Related Threads
Hot Rod Forum
2.2M posts
175.9K members
Since 2001
