i have an idea - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2004, 04:35 PM
black86z28's Avatar
i have an idea
i was at work today and got an idea, what would happen if you could get a 350 crank into a 305 block, basically stroke the 305?
is this possible and/or what other parts would be needed
just an idea
thanks
russ
Old 02-19-2004, 04:40 PM
bowtienut's Avatar
The stroke is the same for both engines.
Old 02-19-2004, 05:02 PM
black86z28's Avatar
so basically there would be no advantage to putting the 350 crank in the 305?
thanks man
Old 02-19-2004, 05:21 PM
Erk Erk is offline
It'll be a 350.
-Eric
Old 02-19-2004, 05:51 PM
black86z28's Avatar
hahaha ok, thanks man, now that u guys told me that, it makes sense, sorry for the dumb question
how bout a 283 with a 305 crank?
i dont think the journals are the same size, but since im on the subject of stupid questions i figured why not?
thanks a lot
russ
Old 02-19-2004, 06:22 PM
Super Chevy's Avatar
BRB carring
it would be a 328.
Once you go flat black you never go back.
1966 El Camino
1992 Dodge Shadow
1986 S-10 Blazer 4x4 Hot Rod
1970 Chevelle
1966 Chevelle 4 door
Home Made Go Cart
Old 02-19-2004, 06:55 PM
black86z28's Avatar
will the crank fit in the journals, and what else would i need
thanks man
Old 02-19-2004, 07:00 PM
NAIRB's Avatar
I have never done this myself. I have put small journal 327 cranks in 283 blocks, but I'm not sure if you will have enough clearance in a 283 for a 3.48 inch stroke. You will definitely have to get out the grinder to make it clear.
Old 02-19-2004, 08:04 PM
black86z28's Avatar
the grinder is no big deal, but what rods would i need?
the 350 rods or the 283 rods or something else
thanks man
Old 02-19-2004, 08:12 PM
283 and 350 rods are the same lenth. The main bearing journals in a 283 are smaller than the 350/305 ones
Old 02-19-2004, 10:00 PM
BRB carring
were there any small journal 350's? the early ones?
1966 El Camino
1992 Dodge Shadow
1970 Chevelle
Home Made Go Cart
Old 02-19-2004, 10:02 PM
No there were small journal 327's but not 350
Old 02-19-2004, 10:15 PM
BRB carring
hmmm...
a 283 block with a small journal 327 3.25" crank would make a 306
and a 327 small journal block with a 283 3" crank would make the famous 302.
you could make two interesting engines from to normal engines.
has anybody ever tried a 306? it would probly be a little more torquey than a 283. but it would probly be a waist of a good 327 unless u just had a 327 or 307 crank lying around.
never mind, that would just make a 307, i forgot to round up.
1966 El Camino
1992 Dodge Shadow
1970 Chevelle
Home Made Go Cart
Old 02-19-2004, 10:18 PM
a 283 with a 327 crank is a 307 which is exactly how chev made the 307 with the exeption of the fact that gm used a large journal crank
Old 02-19-2004, 10:24 PM
BRB carring
indeed, its too bad they chevy made different journal sizes. it would be cool to take a 4.125" bore with a 3" stroke, now that would be cool, a 321.
1966 El Camino
1992 Dodge Shadow
1970 Chevelle
Home Made Go Cart
