Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > General Rodding Tech
  #91
Old 08-20-2008, 08:39 AM
88lowrider's Avatar
88lowrider 88lowrider is offline
Helmar
Firewall set back
Wow.
Looking at how tight that is for the distributor, I would say, no using points and condenser in the distributor. It looks like it would take some doing to get the cap off
The more pictures I see of your Model A, the more I am in Copy mode
I see you used one of those electric fans to cool the radiator, must be due to how low the fan sets and how much room you had to work with.
Did you have to use a special water pump and pulley or was you able to get away with the stock style?
We are tucked in on the edge of a mountain range (Olympic mountains ) at about 570 feet up looking down at the Hood Canal in Washington state.
Its all pretty much green forest, no, its All green forest here so it would take one big tsunami to get us.
I have seen the floods but always lived up in the mountains for the most part. Don't know why other than being a Norwegian with a name like Helmar
I am going to go look into your Photo album to see what you have added.
Any and All pic's of your Model A details are good
Helmar
Old 08-20-2008, 09:29 AM
Frisco's Avatar
Frisco Frisco is offline
Glad To Be Here
re: I have a Model A Pickup to build, have Lots of questions.
Originally Posted by 88lowrider
Wow.
This is a large cap GM HEI distributor. Pictures are a little deceiving. The cap can be removed easily. The distributor can be removed when using an Edelbrock Performer intake. When I installed the Edelbrock Performer RPM Air Gap there was not enough room to install the distributor due to the increased casting thickness of the intake manifold at the distributor hole. I had to place the distributor in the intake and install the intake/distributor as a unit. A little tricky but do-able. Better than pulling the engine to install the distributor.
That is correct. I ran the fan 100% of the time. I wired a relay in the system to alert me by lighting a warning light if the fan ever lost power. I do not trust the aftermarket thermostatically controlled switches for electric fans. I have seen many of them fail on others vehicles.
I used a stock short style Chevy water pump.
I also live in the mountains of Western North Carolina. The elevation varies but I am at 2400 feet. The Pigeon River flows from a higher elevation on down, eventually into Tennessee. There is a levee along the section of the river closest to me, but it wasn't high enough when those two hurricanes (Frances and Ivan) came thru. The water level exceeded the 100 year flood plane that time and did a lot of damage in this area.
Old 08-20-2008, 11:26 PM
88lowrider's Avatar
Helmar
Frisco, it sure looks as it can be done.
Right now that little 283 that I have has the stock intake with a two barrel Rochester on it (might be a carter) and the stock distributor.
I will sure think about an electronic ignition system for it.
Getting closer on what parts and pieces to start to gather up.
I still need to get time to put the Model A frame up to see what I have to start with first.
I have to end this message to go look to see if you showed or sent me your rear end setup on your Model A.
Helmar
Old 08-23-2008, 03:43 PM
Chevrolet4x4s Chevrolet4x4s is offline
 Chevrolet4x4s's barnstar
The idea
IMG]http://www.hotrodders.com/forum/attachment.php?attachmentid=32018[/IMG]
The beggenining of the reality
Shane
Old 08-23-2008, 03:59 PM
chlsnk's Avatar
chlsnk chlsnk is offline
"Love what you do for a living
Originally Posted by F&J
...Ford... as in stock Pinto & M2
You said you were a boneyard builder and on a budget. The stock ford stuff can be used like on this 32. Not as pretty as aftermarket tube A arms, but at least it won't fall apart like some repro front ends.
There is a motor & body "laying" on the above chassis right now, but I most likely will be pulling it out this week. I could then put up some detailed pics of how it is mounted to the rails. I am not using this frame or front end, I went with a dropped I beam and transverse spring instead.
I have ridden in I beam cars at the speed you spoke of, and don't find it to be squirrely.
Whoa what kind of frame is that? It have MG rostyle wheels on the front and they are only 4 lug what is it?
Old 08-24-2008, 11:10 PM
Looks like a ford frame with different suspension grafted on.
Shane
Old 08-25-2008, 05:45 AM
Deuce Deuce is offline
CURMUDGEON / MODERATOR
 Deuce's barnstar
It is a 1932 Ford frame with Pinto/Mustang II IFS ... from 1974 to 1978
Deuce
I went to the school of hard knocks ...
where the tuition is high but the retention is exceptional !
Old 11-06-2008, 11:50 AM
88lowrider's Avatar
Helmar
Gathering parts
Well, I ran out of cash real fast.
My next step is to build a shop on our property to work on this project.
Kind of hard to do it on the Car Hauler.
The shop were I work is where the truck is and its not looking good for space to work on it there.
I will be picking up the stock frame and the rest of the truck to bring home for now. I hate it when things change like this, oh well....
HJ
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "I have a Model A Pickup to build, have Lots of questions."
1940 Ford pickup box and door questions? Skiman Body - Exterior 7 11-30-2005 07:39 AM
New to boards, '74 Camaro, lots of questions (long) Felix_the_caT Engine 12 04-27-2005 03:21 PM
Model A pickup body swaps alegath Body - Exterior 4 02-21-2004 01:03 AM
Spare Tire Mount on 54 Chevy Pickup : 3 Questions horvath Body - Exterior 5 03-19-2003 05:49 PM
31 model a pickup maddog200485 Body - Exterior 1 03-15-2003 06:57 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
