I have a Nissan and i have a Q - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2002, 05:40 PM
Wink I have a Nissan and i have a Q
I have a 88 nissan sentra i know its ot a hot rod but i thnx theres a elec problem with it i turns over and all but just wont start it back fires occasionaly and i just replaced the plugs in it and i just have some really bad trouble with it can someone give me a answer to this problem?
Old 10-06-2002, 05:50 PM
aka Duke of URL
Question
[quote]...i just replaced the plugs in it...<hr></blockquote>
Did you replace the plugs after or before you had the no start problem?
Old 10-06-2002, 08:34 PM
Wink
i had replaced them after i had the starter problem.
Old 10-06-2002, 08:59 PM
aka Duke of URL
Question
Is this a 2.0L 8 spark plug fuel injected OHC?
  • Check for proper spark. Remove one plug and ground it to the engine with a pair of vicegrips. Check for a hot blue spark.
    (Ignitor or secondary ignition)
  • Pull one intake side spark plug. Does it smell of or is wet with fuel after cranking?
    (Proper fuel delivery.)
    (Fuel pressure and regulator and clean filter).
  • Verify valve timing
    (Timing belt slippage or failure).
This will get you started. You need three factors for fire...air, fuel and timing (compression).
Your ECM is self diagnostic on this model I believe.
[ October 06, 2002: Message edited by: KULTULZ ]</p>
