I have no idea what logic was used to build my motor... advice..? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2008, 11:16 PM
So... I picked up an IROC camaro and i started looking into the drivetrain and what I have... so from a visual inspection of the motor...
Block: 5.7L
Carb: Edelbrock 800cfm w/ elec choke
Intake: Holley Street Dominator
Heads: 333882 casting GM heads
Cam: Lunati Duration 290/ 297, Lift .490/ .490...?? Guy said its a .490 lift lunati... this is my guess.
Exhaust: Edelbrock TES headers to 3" cat to 3" catback
Seems like an awful lot of carb... not really a good setup. Any feedback? It's just a driver for now... I' m thinking I need to ditch the 800cfm carb at the least. What kind of power do you think I am making with this? I'm doubting even 300. Trans is a TH350 with 2800 stall.
any comments / advice to make this a decent driver would be appreciated. Eventually... I'd like a nice blower setup in there.. but for now I want to focus on putting the interior/suspension together and the last thing I will do is the motor as tht is the highest $ item.
thanks guys!
Rob
Old 10-28-2008, 01:18 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Not knowing the rest of the internals, its hard to say. Most 3rd gen F-bodies were delivered with an engine in the 150-210 hp range, so if its based on that shortblock I don't think even 300 hp. The cam would shift the curve way beyond what the 882s could flow.
For now, if it runs well and doesn't offer any compelling reasons why you should change, leave it alone. In the meantime, do a compression test and see what you get. That way you can vaguely estimate static compression and determine the next course of action.
Old 10-28-2008, 07:42 AM
Banned
It actaully doesn't look like a bad combination. The cam is not that mismatched to the heads- its a lot lazier cam than you would imagine with those long adv. duration numbers. The carb is a little overkill, but its not terrible by any means. The first thing I would look at doing would be a 383 kit. And then of course cam and heads. Its not a bad cam, but there are many better, same with the heads- not terrible, but a long way from great. With that setup I'd guess about 220 hp to the wheels.
Old 11-11-2008, 10:09 AM
Talked to the guy that built it and the heads had some work done as well as high compression pistons. Valves are 2.02/1.60 opposed to 1.94/1.50 stockers I guess. It'll do for now haha. still sounds mean at least.
350 build up opinions? Artemis Entreri Engine 17 08-09-2006 02:48 PM
Idea - what do you guys think of this... ckucia Hotrodders' Lounge 8 04-01-2006 01:17 AM
Just bought 400 chevy, build idea and some questions? Warrant Engine 10 01-11-2006 07:50 AM
327 build up using 1964 and earlier parts ONLY chopperimpala Engine 23 10-06-2005 02:07 PM
Build a kit car Dutchman General Rodding Tech 9 09-23-2005 05:39 PM
