Engine is a 350 chevy with a computer controlled distributor coil-in-cap type. The engine is on a stand so the distributor is not plugged in to the computer if that makes a difference. The module and coil are new. The pickup coil tested good. I've got the distributor clamped down to the intake for grounding. I have that 3 wire connector going to the cap with the pink wire on the BATT side. I have 12 volts going into the single wire that plugs into the BATT too. I used a timing light to check it and it didn't flash. Wires are a few months old, used only a couple of times. Plugs are new. Cap and rotor are a few months old but only used a couple of times, I see no cracks. Anyone know what else to check? I would really appreciate advice, I don't know what else to do. I don't think it's supposed to be this hard. :smash:
Just so make sure I'm following you right. The distributor is hooked only to the positive side of the battery?
What year exactly is this engine?
Remember, the ignition module has to give a reference signal to the distributer so it knows where its at. In other words, yes you have power and ground present but no trigger/signal, that's why your timing light is not working either.
the 5 pin module you have is an antiquated module used RARELY on some 78-79 models, usually oldsmobiles. You should use a 4 pin module and forget the 5 pin module. The 5 pin requires an extra spark computer module to control the bias on the extra (5th) terminal wich is what advances the timing. If it is not sparking being hooked up with 4 terminals used, it probably isnt any good.
Sounds like you did away with the 7-8 pin setup (good move) and are running the 4 pin wiring, trouble is without weights or a vacuum chamber there is no way to control timing.
wait no I have the 5 pin wiring and its using a new 5 pin ignition module, I don't see why that would be the problem?
I should try using the 4 pin module?
If you can, plug the 4 pin in just to see if you can get spark.I have only seen one or two of the 5 pin modules and I dont know if it will spark without the fifth pin hooked to the timing computer.
found a few articles on the five pin , the fifth pin changes the timing by either applying a voltage or ground depending on original application.It should spark without the fith wire hooked to anything... regardless.
ok I learned that there are 3 different 5 pin modules and I have to make sure I have the right one since they aren't interchangeable (like they weren't hard enough to get already right?) and I have to make sure the wires on my pickup coil with a yellow connector are plugged into the right side of the module.
Thanks for that article latech. do you know how I can find out which 5 pin module I need? I was thinking that I could match the letters to each pin.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
