Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I have oil on the wrong side of the engine............
Old 02-08-2002, 04:28 AM
gbovaird gbovaird is offline
You should have a filter (vent) on one side and a pcv valve and hose which connects to the base of the carb on the other. this should cycle air through the motor and stop any unwanted biuld up of pressure within the motor. It is possible that you have biult up some pressure and forced the oil by the gaskets. Hope this helps.
