Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I have oil on the wrong side of the engine............
Old 02-17-2002, 08:14 AM
dmorris1200's Avatar
dmorris1200 dmorris1200 is offline
doesn't play well with others
Post
you can run breathers on both valve covers, we did that in the pre-emission era, but it is not nearly as good as a pcv system, the pcv uses engine vacuum to not only prevent crankcase blow-by pressure's but also to draw fresh air into the motor trough the breather on the other cover,it also keeps your motor much cleaner. The pcv is also a controlled vacuum leak, if you add one to your system you may need to re-jet your carb to keep your engine from running lean
BUILT FORD TOUGH
