I have to rebuild, will this get me close to 400 hp - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2008, 06:22 PM
I'm sure you experts here get tired of these posts but after hours of research online it seems nobody has actual experience or real data to back up opinions.
I was going to build a motor to run a weiand 144 for my 350 but squeaking rod has changed my mind and I decided against using the blower. Here is what I am thinking of instead.
Eagle Specialty Products rotating assembly w/hypereutectic pistons .30 over, CompCam kit 249-K12-210-2, sportsman II 64cc heads or new set of vortecs if they will make the power, roller rockers, air gap intake, holley 770 street avenger carb.
Any suggestions?
Old 11-18-2008, 07:37 PM
Originally Posted by F-BIRD'88
You'll come up a bit short of 400hp.
Here is a easier 400hp+ combo.
Build a 355ci flat top piston motor
prepare the block so that the piston deck clearance is 0 {"0 decked"}
Add Edelbrock Etec 170 64cc chamber cylinder heads
Edelbrock performer rpm air gap intake manifold (Vortec).
Comp cams XE274H-10 cam
long tube 1-5/8" headers.
This is a popular simple combo that works well.
Thanks for the quick response, I was hoping not to have to spend that much on heads (I know hp = $$) the extra $500 is going to be a little over my budget.
Old 11-18-2008, 07:54 PM
Banned
The Etec's are nice, but there's better heads for that kind of money. I would look around at some onlie auctions or classifieds, you want around a 190cc intake rummer and a 64cc chamber. Aluminum is prefered, but either material will do. Machined chambers, not rough as cast finish.
Old 11-18-2008, 11:21 PM
techinspector1's Avatar
Wiki Edits: 326
Here are 108 small block chevy combinations. Go through them, pick the one you like and purchase the components shown....
http://www.ryanscarpage.50megs.com/combos1.html
th 400 rebuild gone wrong circusboy90210 Transmission - Rearend 7 07-15-2008 10:20 PM
1968 pontiac heads David Goetz Engine 10 12-21-2006 03:01 PM
chevy heads desireable for the rebuild of a 400 for my 3/4 ton 86 2x4. nh32u Introduce Yourself 4 12-17-2005 06:31 PM
how much hp can a 4 bolt 400 take? 406 ss monte Engine 14 08-04-2004 10:04 PM
Rebuild kit for a 1950 chevy 87 hp spikes_50 Engine 2 05-20-2003 12:42 PM
