Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I have stock Gen IV 454 & 781 Heads, Compression ????
  #27 (permalink)
Old 03-01-2012, 03:44 PM
matts37chev's Avatar
matts37chev matts37chev is offline
& matts38chev
Last journal entry: Try again
Originally Posted by cobalt327
Sorry, matts37chev- I didn't see the first page of the thread before responding. The comment about the heads was more to add something on-topic instead of just flakking the guy for the street racing comment.
In any event, wild man- check out this build to get an idea of what kind of flow (CNC ported AFR Magnum 315's w/2.25" x 1.88" valves milled to 110 cc chamber volume, being fed by a Vic Jr.) and how much cam duration (254/260 @ 0.050") is needed to make 738 HP/666 TQ based on a Gen. VI 502 short-block (GMPP p/n 24502619)- an engine w/a lot larger bore diameter and a 4" stroke (giving less piston speed) than an engine based on a BBC 427 TD.
If you lower the power expectations by at least a hundred or so, things will become much more "doable", IMO.
you dont need to be sorry, i'm just glad i'm not the only one thinking this way
