Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I have tried , ....no luck yet??????????????
Old 12-20-2012, 08:21 AM
bsa_bob's Avatar
bsa_bob bsa_bob is offline
I have been in the process of getting this 348 stock.....settin outside for 8 years chevy motor runninig. I have fire and gas.............it hits and tries eveytime.when you ad lots of gas.........but then it slows down with the starter getting tired.Its right on the brink ..you might say of running,,,,,,,,,,,,,,,,,,,but just won't keep firing long enough .or gas enough. i don't have a clue.I am using "either" and gas. With a GOOD holley carb,A choke prop holding the butter fly open on the front two barrels.Can this be a weak coil its an old accell[yellow]nere wires ...8 years ago . you can ground a plug off the , engine block. Big! hot !blue spark / Any one care to take a whack at this . I am intently listening thanks for anthing bob s
ps the distributor is not loose and it supposedly was driven in to where she sat.
