Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I have tried , ....no luck yet??????????????
Old 12-20-2012, 09:03 AM
John long John long is offline
Originally Posted by cobalt327 View Post
Good spark rules out most ignition probs.
Check to see if the timing chain is shot. Check the rotor position w/#1 at TDC. Should be just before #1 or #6 distributor cap terminal. If it's not the timing chain has slipped or is very worn (and a car will run like that sometimes- but not well. And restarting it could be very hard).
Could be the rings are still stuck and it has very little compression. A compression test would tell that tale.
Don't rule distributor installed a tooth out.....
