Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I have tried , ....no luck yet??????????????
Old 12-20-2012, 05:31 PM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
Look at the harmonic balancer and timing tab...... bump the starter till you get TDC, look at the dizzy cap and get a reference to where the #1 plug wire is located, pull the dizzy cap off and see where the rotor is pointing...... if it's not pointing to the #1 plug wire reference point then rotate the dizzy body till it is (you're going to have to take the cap off several times to do this) That'll get you really close to a fire solution.
