I have tried , ....no luck yet?????????????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2012, 08:21 AM
bsa_bob2's Avatar
I have been in the process of getting this 348 stock.....settin outside for 8 years chevy motor runninig. I have fire and gas.............it hits and tries eveytime.when you ad lots of gas.........but then it slows down with the starter getting tired.Its right on the brink ..you might say of running,,,,,,,,,,,,,,,,,,,but just won't keep firing long enough .or gas enough. i don't have a clue.I am using "either" and gas. With a GOOD holley carb,A choke prop holding the butter fly open on the front two barrels.Can this be a weak coil its an old accell[yellow]nere wires ...8 years ago . you can ground a plug off the , engine block. Big! hot !blue spark / Any one care to take a whack at this . I am intently listening thanks for anthing bob s
ps the distributor is not loose and it supposedly was driven in to where she sat.
Old 12-20-2012, 08:58 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Good spark rules out most ignition probs.
Check to see if the timing chain is shot. Check the rotor position w/#1 at TDC. Should be just before #1 or #6 distributor cap terminal. If it's not the timing chain has slipped or is very worn (and a car will run like that sometimes- but not well. And restarting it could be very hard).
Could be the rings are still stuck and it has very little compression. A compression test would tell that tale.
Old 12-20-2012, 09:03 AM
Don't rule distributor installed a tooth out.....
Old 12-20-2012, 09:13 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'm going by the statement " the distributor is not loose and it supposedly was driven in to where she sat".
If the distributor was a "tooth out", turning it to restore the correct timing would be all that's needed. The only thing that might prevent that would be the vacuum advance hitting the firewall or intake, preventing the timing from being set right. But I get your point- the timing could be off. Checking the rotor position at TDC will show that.
Old 12-20-2012, 09:46 AM
Hey bob,
Sounds like the old Lack O comperssion.
Pull the plugs, give all cylinders a few squirts of oil crank it over 10 or 9
times. Have a cup of coffee.
Crank the engine over again w/o plugs. Install plugs and start it.
Old 12-20-2012, 11:57 AM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
http://www.hotrodders.com/forum/atta...1&d=1356028861
Bob:
The starter will pull power away from the coil unless The "I" (ignition) wire is hooked up! Hook it directly from the starter to the + coil terminal and not through the resistor!! It only supply's power to the coil when you crank the engine!! When the key returns to run position the power doesn't come from that wire any more it comes through the resistor! If your still using a jump wire from the battery by pass the resistor momentarily till it starts and then use the resister once its running!
I'm not saying that's why it wont start but it could compound any other problem your having
Ive also seen animals plug the exhaust systems up so bad as it wouldn't let the engine run!!!!!
Chris
Old 12-20-2012, 02:25 PM
bsa_bob2's Avatar
no balast resistor on this car.Distributor is loose.............Where can i set it at to rough start it? vacume advance; ex; clear back to fire wall .....half way out forwards........... or all the way to where it stops to the front seems i remember doing this years ago but i could be wrong thank you for any thing on this. bob s
Old 12-20-2012, 04:23 PM
T-bucket23's Avatar
Wiki Edits: 26
Snug it down and try moving it CCW a little at a time. Dont move it more than a 1/16th of an inch at a time. It must be close if you say it has fired a few times. Sounds like it is a little retarded from your explaination.
A fresh set of plugs may help you. If you have been cranking it a lot the old plugs may be loaded up. I would not use either as it can do more harm than good.
Chet
The Following User Says Thank You to T-bucket23 For This Useful Post:
Old 12-20-2012, 04:27 PM
bsa_bob2's Avatar
thank you much i'll try that.the plugs look pretty wet and black right now.. bob s
Old 12-20-2012, 05:31 PM
EOD Guy's Avatar
Look at the harmonic balancer and timing tab...... bump the starter till you get TDC, look at the dizzy cap and get a reference to where the #1 plug wire is located, pull the dizzy cap off and see where the rotor is pointing...... if it's not pointing to the #1 plug wire reference point then rotate the dizzy body till it is (you're going to have to take the cap off several times to do this) That'll get you really close to a fire solution.
Old 12-20-2012, 08:32 PM
Piland Triangle, Elroy, TX
start it on carb cleaner. it'll save you the cranking & you' will learn a lot about the motor condition quickly.
Old 12-20-2012, 09:11 PM
http://www.hotrodders.com/forum/atta...1&d=1356062624
Bob: the white braided wire is the resistor !!! Look for it on the fire wall! There is no block resistor on the 60s chevys! Its the wire itself!! You must have one on the car on the fire wall if it hasn't been removed. This was the only picture I could find that showed the white braiding!! Its between the blue and purple wire in the pic! Forget the #1 & #2 They were on the picture and mean nothing!
Are you working outside on that Bob or in a warm garage?
Jester
The Following User Says Thank You to painted jester For This Useful Post:
Old 12-21-2012, 05:16 AM
EOD Guy's Avatar
Being that you are getting a blue hot spark when grounding the plug on the block and you have verified the #1 rotor-to-dizzy cap post position and as suggested above with the WD40 in each plug hole to free up the rings....... I'd say sounds like somewhere your plug wires have been switched and your firing order has been screwed up.
Verify you firing order is correct.
Old 12-21-2012, 06:47 AM
bsa_bob2's Avatar
Jester
NO i quit working o/s 45 years ago i love hotrods Chris..........but.not enough for that. Did a little workin o/s..when i first got married. Chris.i am going to sell this kar, or trade towards a 55 chevy or?. if thats possible .This motor looks great but the rest of the kar ...SUCKS see ya thanks for the help talk at ya again Chris bob s
Old 12-21-2012, 12:25 PM
bsa_bob2's Avatar
I have the rotor alined up with the "cap". i have been moving the distri; back a tad at a time, The engine now turns much faster, BUT..i get a tight spot where it slows momentarily,... then resumes turning faster. wet plugs now, gas poured down the carb.this thing oughta at least try to fire.it won't even try now. please hang in there til i get her lit ..... the kar not my wife!............. tryin to lighten the mood here.
The luck of me moontanker Off-Topic 1 12-07-2008 09:57 AM
if it werent for bad luck, id have no luck atol engineman302 Engine 0 05-16-2005 05:41 PM
Wish me luck Stitch Hotrodders' Lounge 8 12-30-2003 06:10 PM
Wish me luck Rubberman2003 Electrical 2 11-21-2003 08:07 PM
wish us luck spooki Hotrodders' Lounge 7 08-27-2003 10:30 PM
