I hope someone can help - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2013, 01:08 AM
I know this ain't no hot rod,but I have been working on a 1996 Ford F-350 4x4 with a 7.3DI diesel and so far last year the IDM mounts on the inside of the drivers fender an it got water in it so I replaced it with a rebuilt one,then I replaced the valve cover gaskets and the inner injector wiring,I replaced the injectors and the fuel pump,truck ran fine,this year,I replaced the cam sensor with one that ford says will not burn out,well it did three times,and the truck sat in the drive way for about two months and would not start,tried to read the computer but every time I tried to read the KOEO codes,the reader would shut off,it will read the present codes but says error when trying to clear them,so I pull the IDM relay and it will read them,then it quit reading ant thing,so I ordered a new computer and a new IDM,I am thinking that the computer already had problems and the IDM I bought my not of been rebuilt right,I hope,has any one else had to deal with any of this
Old 03-26-2013, 03:56 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
diagnostics
Take the truck to a shop with the proper diagnostic tools and the people to interpet the data. Then they can determine what is required to repair the system. Ideally diagnostics can be treated separatly from the repair.
Of course they may have to disassemble something to obtain a diagnosis.
They can then give you quote on the repair cost.
Or you could do the repair.
Throwing parts at a problem is, at best guessing, expensive and doesn't resolve the problem.
vicrod
Old 03-27-2013, 01:05 AM
figured it out
well I pulled the IDM and the computer,the computer because it could not be read,erased,and would shut off the scan tool when I tried to read the KOEO,so when I pulled the computer,if there would of been computer's back in the 20's,I would swear this was one,the case was almost solid rust and the in side looked like it had been under water,I ordered another IDM,so with one coming I pulled the glue off this one to take a look inside,it was bought a year an a half ago and it was a rebuilt,I dried it out with air,and once I cleaned it up,I couldn't see any thing burnt,but I did see where who ever rebuilt this didn't put any of the screws back in the board to hold it down,there is two screws that hold down the plastic part where the wiring plug go's,but the center and back screws was not there,I could see where at one time there was screws,probably when it was new,and the ground connections was corroded from the water,so I cleaned it off,installed three screws,mounted it hooked up the battery's then it fired right up,run's really good and strong,when the new IDM gets here I will use it and keep this one for a spare
Old 03-27-2013, 01:30 AM
forgot
I have a $2,500 upgradable snap on scan tool that I bought in 2005,and I have used it on hundred's of vehicles,the reason I posted a question because maybe some one else has had the same problems,the reason I don't take vehicles to the shop's or dealers is because I can't afford to pay them their price's and second I took a truck almost just like this one back for some repair's that was covered by the warranty,the truck was using oil,they said it was the valve seals,the alternator wasn't charging,this truck was diesel and had less then 60,000 miles,so when I picked up the truck,I had an 14 mile ride home,looking at the invoice,the warranty was charged for a new alternator,plus was charged for a alternator rebuild kit with a new regulater,when I got home all of a sudden there was all this noise under the hood,and steam,I shut it off,well the alternator pulley came off and the belts started whipping around under the hood,ripping out the tranny lines from the cooler,ripped a pretty good hole in the radiator ,and that was the good thing,because you see then they put the valve covers back on,they tighten the valve covers down on top of the wiring harness on both sides in the rear,then the belts did all the damage it stopped me,other wise it would of blown,all the oil had pumped out,the oil level wasn't touching the dip stick afterit set for a few hours,we pulled the oil plug from the pan,and there was less then a gallon of dirty black oil with chunk's of valve guide seals,the invoice also said they had serviced it as well,so you see I m don't have much faith in shops around here,not to say all shops are like this,just this one I know of but I do know I m not like that,and I trust me!!
Old 03-27-2013, 07:51 AM
Irelands child's Avatar
I strongly suggest that you go to the Ford Truck Enthusiasts web site where you will get whatever pertinent info you need to 'fix' your problem.
Here: Ford Truck Enthusiasts Forums - Ford truck and SUV owners and enthusiasts Community And Information Source.
Irelands child
Old 03-28-2013, 01:59 AM
its already fixed by cleaning out the IDM and installing three screws that was not installed when it was rebuilt,the screws that hold and ground the board,it had got water in the IDM when it was sitting with the hood open and it rained on the engine compartment,but it's all good now the workers drove the truck today over 600 miles and they said it ran better then it has ever sense that IDM was installed last year,but thanks
Hello, hope I know some of you Ol'hotrodder Introduce Yourself 4 01-20-2013 12:43 PM
hope to help old school two Introduce Yourself 2 02-06-2011 04:54 PM
I hope I can help moparman440 Introduce Yourself 2 09-01-2008 01:49 PM
I hope someone knows... VERONICA Engine 9 12-11-2004 01:25 PM
last hope blazinwest Engine 10 12-05-2004 06:41 PM
