Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - i just had an idea
Old 10-02-2010, 10:10 AM
boatbob2 boatbob2 is offline
boatbob2
brake problem??????
HI,i HAVE NOT tried this,but,i THINK it will work. find a plug that will screw into the master cylinder (where the brake lines go) attempt to bleed either the front or rear, DO NOT DRIVE THE CAR,if you have a firm pedal,change plug to other outlet, re-install line you removed,try again,this SHOULD at least tell you where the problem is (front or rear brakes) could be bad master cylinder,rubber brake line expanding,bad calipers,wheel cylinders worn out.
