Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I know how to figure total timing... now what?
Old 08-25-2012, 06:25 AM
Greg T's Avatar
Greg T Greg T is offline
www.krusinklassics.net
If you want a bit more throttle response you can limit your mechanical advance curve to about a 16* swing and set the initial at 20*. Also, make sure you have 34* to 36* all in by 3000 rpm. Use a vacuum can with an advance of 10* and use manifold vacuum. You'll have to reset your idle speed and mixture afterwards.
