I lose compression w/ valve adjust - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2009, 09:33 PM
Ok so I am I am so lost I don't even know where to start. Lets start with what I have
sbc 350
speedpro 12 to 1 .040 over pistons
stock length rods
cloyes tru roller timing chain set that I installed on the 0 marks
edelbrock performer plus cam (duration at .050.. 204 intake 214 exhaust) (Lift 420 intake 442 exhaust)
edelbrock performer rpm heads (2.02 intake 1.60 exhaust 64cc)
I installed everything correctly and did the valves the proper way..... exhaust starts, intake, intake up and fully closed, exhaust.... 0 lash + 1/2 turn)
did timing right
installed and did not start... pulled plugs and it feels like no compression (pulls finged in and does not blow it back off) so i backed all the rocker arms off and it has compression (blows my finger off) redo valves and same thing, redo to 0 lash and still the same thing (and I have tried using different adjusting methods). PLEASE HELP
Old 11-22-2009, 09:41 PM
Zimmo's Avatar
If you are adjusting hyd lifters, they will hyd lock & cause the valves to stay open. About the only thing you can do is to let them sit overnight to allow them to bleed off some pressure.
Was this engine previously run, or were the lifters submerged in oil?
Old 11-22-2009, 10:07 PM
not submerged... never ran
Old 11-22-2009, 10:20 PM
Zimmo's Avatar
Did anyone pre-fill & pump up the lifters by hand before installing them?
Old 11-23-2009, 08:45 AM
no i didnt pump up the lifters the first time. and the up and down method is what I always use. yes it is alot of compression but this motor is in an off road race truck that I run race gas in. and now i am wishing i would have not gone so big with the dome. I am so frustrated with this at this point, I am ready to give up.
Old 11-23-2009, 10:29 AM
airboat's Avatar
If all else fails use this procedure. I think the manufacturers are using a longer ramp on some of the new cams. all I know is I got bit after never having a problem for 35 years?
http://www.centuryperformance.com/ad...h-spg-149.html
Valve Adjustment Procedure - The Quick and Accurate Way:
First, view this little chart below for Small and Big Block Chevy Engines that I made and see if you can understand it. There is more of an explanation below the chart. For other engines you will use the firing order that matches your engine to create a similar chart. This chart is based upon "opposite" cylinders of your firing order. (see below)
Intake Valve Adjustment: ENGINE OFF!
with #1 cylinder Intake Valve at full valve lift .... Adjust #6 Intake Valve
with #8 cylinder Intake Valve at full valve lift .... Adjust #5 Intake Valve
with #4 cylinder Intake Valve at full valve lift .... Adjust #7 Intake Valve
with #3 cylinder Intake Valve at full valve lift .... Adjust #2 Intake Valve
with #6 cylinder Intake Valve at full valve lift .... Adjust #1 Intake Valve
with #5 cylinder Intake Valve at full valve lift .... Adjust #8 Intake Valve
with #7 cylinder Intake Valve at full valve lift .... Adjust #4 Intake Valve
with #2 cylinder Intake Valve at full valve lift .... Adjust #3 Intake Valve
Exhaust Valve Adjustment: ENGINE OFF!
You will notice that this is the same procedure and sequence as the intake valves listed above. Only now you are adjusting ONLY the exhaust valves the same way.
with #1 cylinder Exhaust Valve at full valve lift .... Adjust #6 Exhaust Valve
with #8 cylinder Exhaust Valve at full valve lift .... Adjust #5 Exhaust Valve
with #4 cylinder Exhaust Valve at full valve lift .... Adjust #7 Exhaust Valve
with #3 cylinder Exhaust Valve at full valve lift .... Adjust #2 Exhaust Valve
with #6 cylinder Exhaust Valve at full valve lift .... Adjust #1 Exhaust Valve
with #5 cylinder Exhaust Valve at full valve lift .... Adjust #8 Exhaust Valve
with #7 cylinder Exhaust Valve at full valve lift .... Adjust #4 Exhaust Valve
with #2 cylinder Exhaust Valve at full valve lift .... Adjust #3 Exhaust Valve
Now I'll Provide an Explanation:
What you see above is adjustments being made on "opposite" valves on the engine cycle. The small and big block Chevy engines use a firing order of 1-8-4-3-6-5-7-2. What you do is separate the order into the two sides of the firing order. These are "exact" opposites that put the opposing valve at the correct location for adjustment, meaning the back side (base circle, or heal) of the cam lobe (see image at left).
Looking at the chart below you will see that #1 is opposite #6, and vice-verse, on through the firing order. This holds true for both intake and exhaust valves.
olds #5 head johann Engine 1 07-30-2006 11:05 PM
valve adjustment 383 stroker solid lifter cam 73luvdrag Engine 4 05-15-2004 04:01 AM
Please HELP valve adjust? 1985fiero Engine 10 05-03-2004 07:50 PM
big block chevy valve adjustment trouble,no compression dufrain Engine 11 09-28-2003 09:07 AM
Cam Help black66 Engine 3 05-12-2003 07:15 PM
