Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I need an adjustable timing pointer...can anyone offer any pointers? heh
Old 08-17-2012, 06:54 PM
Silver Surfer's Avatar
Silver Surfer Silver Surfer is offline
More machine than man
Last journal entry: bwaahhaahahaaahhaa
I got this 6.61" damper from Trickflow and I had no idea how hard it would be to find a timing tab to work with this! Sheesh.
Trick Flow Specialties TFS-19000 - Trick Flow® Track Max® Harmonic Dampers - Overview - SummitRacing.com
I found a couple of somewhat cheap pointers. One is for 6.750" and one is for 6.600" diameter balancers. I would like to go use the one for 6.600" if possible to help reduce any paralax issues...but not sure if I will have any clearance issues on the 6.610" balancer. Any insights? Or more practical and cheaper solutions?
Moroso 60110 - Moroso Timing Pointers - Overview - SummitRacing.com
Summit Racing SUM-B64261 - Summit Racing® Adjustable Timing Pointers - Overview - SummitRacing.com
I think something cheap like this would lead to major paralax since it also clears 8" balancers.
Spectre Performance 4237 - Spectre Performance Timing Pointers - Overview - SummitRacing.com
