-   -   I need an adjustable timing pointer...can anyone offer any pointers? heh (http://www.hotrodders.com/forum/i-need-adjustable-timing-pointer-can-anyone-offer-any-pointers-223014.html)
Silver Surfer 08-17-2012 07:54 PM
I got this 6.61" damper from Trickflow and I had no idea how hard it would be to find a timing tab to work with this! Sheesh.
Trick Flow Specialties TFS-19000 - Trick Flow® Track Max® Harmonic Dampers - Overview - SummitRacing.com
I found a couple of somewhat cheap pointers. One is for 6.750" and one is for 6.600" diameter balancers. I would like to go use the one for 6.600" if possible to help reduce any paralax issues...but not sure if I will have any clearance issues on the 6.610" balancer. Any insights? Or more practical and cheaper solutions?
Moroso 60110 - Moroso Timing Pointers - Overview - SummitRacing.com
Summit Racing SUM-B64261 - Summit Racing® Adjustable Timing Pointers - Overview - SummitRacing.com
I think something cheap like this would lead to major paralax since it also clears 8" balancers.
Spectre Performance 4237 - Spectre Performance Timing Pointers - Overview - SummitRacing.com
PatM 08-17-2012 08:52 PM
I'm hard pressed to believe that .005 clearance difference on the radius would matter. What counts in this case is the ability to adjust the pointer to the right circumferential position to match your engine.
PatM
cdminter59 08-24-2012 12:26 PM
Timing pointer
The Summit Racing brand will work fine. These are adjustable too.
