i need advice on my engine build
I have a 350 bored 030 over and just recently bought a lunati 286 series cam 489 lift. I am Going to b running mostly on the street with a 4 speed! I need a little advice on head selection and roller rocker ratio. I have a brand new elderbrock performer intake it says its only up to 5500rpm the cam I bought the range is 1800-6200 u think I should use the intake? I want aluminum heads!
What's the part number of the cam? What kind of pistons are in the motor? Flat-top with valve reliefs, flat-top with a trough, flat-top with reliefs and a circular dish, D-cup, domed or what? How far is the piston down in the bore with the piston at TDC? |
I don't have a proper micrometre but my tape measure says 3.5 inches at top dead center the cam is 60103 and the pistons have a flat top with four eyebrows or half moons! I'm learning a lot about all this I'm still pretty green! I appreciate all the help!
I don't want crazy power just a nice reliable engine! I bought a half restored project and it came with a short block!
What would b a better choice for street and pump gas application?
The Edelbrock performer heads have always been a good head for basic street use. With what it sounds like you have, and your experience level, I would think they would be a safe bet.
Mm |
.........and no offence but when you take it apart and REALLY when you put it back together get an experienced engine tech to help you. If you don't you can screw up all the new parts you bought because it all has to go back togeter properly.
Thanks for the advice! I definitely will have somebody that knows what there doing to help! Elderbrock street heads 180cc would it b better to have the 64 cc or 72cc what kind of comp difference would it be?
The very first thing you should buy is something like this http://m.summitracing.com/parts/SAD-SA116 before you start dropping thousands of dollars on something that your completely in the dark on!
Mm |
What would b an ideal compression ratio for a pump gas engine? Mileage I'm not too concerened about cause its gonna b a Sunday driver
Learn about dynamic compression ratio (DCR) because that will determine if your combination of parts are compatible and will run on pump gas. There are a number of calculators on the net. I like this one:
http://www.projectpontiac.com/ppsite...tio-calculator It is for Pontiacs, but works well for any engine make. You should also learn about "quench" and what head gasket to use to figure proper quench for your engine. |
| Pontiac engine build advice? | scottp | Engine | 8 | 02-17-2012 07:46 AM |
| 350/290 GMPP Engine Build need advice(cam, intake etc) | Chevyboy_0 | Engine | 5 | 08-26-2010 12:32 PM |
| Engine build advice for street rod | 77bronco_ed | Engine | 18 | 12-23-2009 11:24 AM |
| Engine Build Advice | dieseldust | Engine | 2 | 05-31-2009 02:25 PM |
| Need Advice on Engine Build Up | MyMalibu | Hotrodding Basics | 51 | 12-02-2004 10:50 PM |
