I need an Air Regulator for my Compressor- Help! - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2006, 08:44 AM
41' Chevy Master DeLuxe Tudor
Last wiki edit: How to title a hot rod
Last journal entry: Engine/Trans Mock-up
Wiki Edits: 2
Can someone tell me about a good air regulator to get so it will keep up with an air impact or cutoff tool and not starve for air so quickly? I have 5 hp 60 gallon with 3/8" hose but the regulator I have just won't stay up with the wrench or cutoff tool when you need it most. I don't want to waste my money that's why I'm asking before I start looking. Thanks.
Old 11-11-2006, 09:14 AM
Y2K Y2K is offline
I'd suggest getting an extra tank for more capacity.
60gal goes fast with airtools like an impact gun.
Old 11-11-2006, 10:57 AM
russlaferrera
Last wiki edit: Threading tips
Wiki Edits: 2
air regulator
I do not use one on any air tools except a spray gun. My line pressure is between 130-150 psi. I have noticed any abnormal ware on any of the air equipment.I have to say all of the air equipment is old, but name brand CP, IR, Snap-On which was BM (Before Marriage) ...russ
Old 11-11-2006, 11:14 AM
Rambo_The_Dog's Avatar
Last journal entry: Shop Remodel Progress
An additional tank will help - although it will run longer to fill up the additional volume.
Harbor Frieght Air Filter Regulator
I have been using one of these with a smaller compressor and it does a pretty good job.
I plumbed a kind-of "stil" setup to with copper to cool the air and give it a collection point before even hitting the filter...
Old 11-11-2006, 04:53 PM
Last journal entry: final pics of first engine swap
I really like seeing how others got theres all setup too. Been using that blue HF filter for a while now and its been working well. Only problem was it leaked at the regulator going into the filter part, just had to reseal it with teflon tape. Can't really be upset for $20.
I used copper too. 3/4" When it wasn't $o much. I liked the setups at www.tptools.com and followed the Sharpe diagrams. I think it was actually designed/started by Kosmoski? Mines up 6", back down, then up 8" again to the regs.
Heres the HF filter after about 40 ft for the air to cool.
Sharpe F88 $44 with an HF filter reg. Same 25 ft retractable like Rambo's shown above This ones after around 65 ft of copper.
I got bored and used some 1/2" pipe after first 25 ft, and used a Craftsman regulater that was given to me. No filter, just an engine bay/misc drop.
Old 11-11-2006, 05:16 PM
Wiki Edits: 31
I use 1 of the HF blue filter regulators for paint, only problem I'v had is the T handle on the drain valve came off so I use the appropriate sized wrench to open it up. works great. use the HF olive green FRL oiler/ regulator, and it works good also, use it for air tools. I also have 2 $40 craftsmen regulators that work good.
Old 11-12-2006, 06:46 AM
It seems that old myths die hard, very hard. An additional tank WILL NOT!! help and 60 gallons is is just fine so don't waste your time and money trying that tired old trick it does not help, not for more than a few seconds anyway and then even this will be lost to the extra recharge time so NOTHING is gained. This has been covered many times before and the size of the tank will determine the on/off cycle of the compressor and not how long you can run a tool that exceeds the capacity of your compressor, you can not get more out of a tank than the pump puts in. TT, you say you have a 5 HP 60 gallon compressor? but what is the CFM rating? Do you have a regulator now or are you running straight tank pressure? If you are running out of air, and it sounds like you are, then no regulator is going to make up for a lack of air from the compressor. Does the impact or cut-off tool start out ok for a while and then die down or does it lose power almost immediately? If it only runs a second or two before losing power then it could indeed be a regulator problem or (more likely) a line restriction. If the tool runs for a while and then slowly loses power along with a corresponding lose of pressure in the tank then the compressor is not producing enough CFM and the regulator is not the problem. Check the lines for a restriction and make sure there are no fittings ANYWHERE in the system that are smaller than the line.
Danny, nice set-up you did a really good job on that
Old 11-13-2006, 01:34 PM
Oh thanks so much Oldred You were a big factor in me wanting to take it this far. I knew you were a good source of info to follow, and really were into these things too.
I had a feeling you were going to mentioned that about the tank assist. Especially on a single stage 60 gallon like mine, wich is a 15 amp US General. When I'm using cut off tools, die grinders and HVLPs, its doing the job, but its constantly on working its tail off like I expected it to. I've been keeping all the regs set at 90 PSI and its been working great so far.
TT66 what compressor and regulator are you using?
Old 11-13-2006, 04:17 PM
True, an extra tank won't help if you are running out of air. But like you say it can reduce cycle time but as in life there are trade-off's with everything and every decision...the trade-off here is it runs longer to fill both tanks...
My experience running smaller compressors is the additonal tank will help cool the air and collect some more of the moisture and another benefit to having an additional tank is - if you plumb it right, its easy to disconnect and take with you for emergency tire repairs and such.
Old 11-13-2006, 04:47 PM
Wiki Edits: 2
I do have one of those Harbor Freight setups pictured above but its an 80's model and I don't have the cfm rating for it. It's too low though. I have a 5hp Quincy but it is a single stage . I know I should have bought bigger but at the time that was $1100 and a two stage was even more. I was having trouble coming up with the even more part. Times have changed in which now you can get a very good 2 stage for that price. My Quincy is no slouch it does keep up pretty good though. I'm pretty sure the restriction is in the regulator orifice which is too small and produces low cfms. The tools start out fine and when the volume of the 3/8" hose runs out the regulator won't keep up. I was just wondering if anyone had some advice on a good regulator that will flow well and reasonably priced. I appreciate all the input so far and nice pictures, very good ideas guys.
Old 11-13-2006, 05:22 PM
TT, First about that compressor, you choose well as Quincy is a VERY reputable outfit and they build some of the best compressors made and if you plan on wearing that thing out before getting a bigger unit you had better be prepared to wait a looooong time! You can believe the numbers that they claim and count on the amount of CFM that will be listed. I would suggest a Sharpe 880a regulator unit but if cost is a concern then some of the newer HF outfits work darn good too. It sounds like you do have a restriction and if so then a new regulator could solve the problem just make sure it is indeed at the regulator and not some place else in the line. I have even seen some of the Chinese pipe fittings with the inside choked down to a fraction of the supposed size so if you have anything like that it might be a good idea to check them out also.
Old 11-13-2006, 05:36 PM
Check out Eaton compressors site, they have 2 different regulators, 1/2" and 3/4" the 1/2" is $60 & the 3/4" is around $80. I have the 3/4" model on mine & get plenty of flow, changed everything over to type V fittings & noticed a big difference by doing that. Comparing these to the type M I had before is like comparing the barrel opening on a .357 to a .22. Get some of the type V fittings if you don't have them allready. They have the added advantage in that the type M fittings will also work with the type V quick connects but not vice versa. Your Quincy 5hp should be plenty, my Eaton is a 5hp single stage & is all I need as it will pump up & shut off while running a cheap (read airhog) 6" DA sander or 1/2" impact.
Good Luck,
Steve
Old 11-13-2006, 09:33 PM
Wiki Edits: 2
Thanks guys, I'll do some checking into that equipment. Fittings.....restriction. I didn't think about the fittings. I need to look at the v type. That maybe the first thing I try. It certainly would be an inexpensive upgrade to see if that's the problem. All very helpful and I appreciate your suggestions.
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Runs Like Crap With Air Cleaner On - why? leejoy Engine 30 11-16-2010 06:08 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
More on Orange Peel KarKen Body - Exterior 36 03-22-2009 02:18 PM
