Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I need an Air Regulator for my Compressor- Help!
Old 11-11-2006, 06:16 PM
matt167 matt167 is offline
Wiki Edits: 31
I use 1 of the HF blue filter regulators for paint, only problem I'v had is the T handle on the drain valve came off so I use the appropriate sized wrench to open it up. works great. use the HF olive green FRL oiler/ regulator, and it works good also, use it for air tools. I also have 2 $40 craftsmen regulators that work good.
