I need ALIGNMENT numbers - please HELP - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2003, 06:17 PM
New Member
I have a 69 Mustang convertible. I have replaced the bushings, tie-rod ends, upper and lower tables in the front.
Using a SNAP-ON alignment machine, I want to line it up. The system does not have the numbers I need.
Does anyone have the numbers in degrees to align it ?
Any info or pointers to web info would be of a great help.
Thanking you in Advance
Glen Brittle aka Zombie
Old 06-18-2003, 07:41 PM
New Member
anyone ? ... I need em bad
Old 06-18-2003, 08:29 PM
dmorris1200's Avatar
doesn't play well with others
This is what my Haynes manual says...
Caster = min -0.75deg optimum 0.25deg max 1.25deg
Camber = min 0.25deg optimum .75deg max 1.75deg
toe-in = 0.125 to 0.250 inches
Old 06-18-2003, 08:32 PM
New Member
Many Thanks ... I will give these to my alignment dude !!!
Glen
