I need alignments specs 1991 olds 88 royale - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2006, 07:40 PM
Hello I need the specs because I just put front struts on my car......oh man that helped.......but it would be wonderful to have the specs...........I couldnt take it any longer the dam car was bottoming out so bad I got tired of it.........of course my fact filled haynes manual writers played paper rock scissors and decided to leave out the specs
Old 09-18-2006, 09:51 AM
powerrodsmike's Avatar
Wiki Edits: 161
my not much better chiltons manual calls for
caster : 2 1/2* - 3 1/2* positive (preferred is 3*)
camber: 5/16* N - 11/16 P (preferred is 3/16* P)
toe in: 0"
steering axis inclination: 1/2* positive
Now all you need to do is figure out how to measure all that stuff
Later, mikey
BE different....ACT normal.
Old 09-18-2006, 10:07 AM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
Your best bet is to take it to a alignment shop and have it professionally done.
Just my .02
Steve
Old 09-18-2006, 10:22 AM
Wiki Edits: 161
C'mon steve you're taking the fun out of it.
A resourceful fellow could spend an entire weekend trying to measure that stuff and THEN take it to an alignment shop to make it right.
Don't ask me how I know that
Mikey
Old 09-18-2006, 10:27 AM
1931 steve's Avatar
Wiki Edits: 4
Exactly
Steve
Old 09-18-2006, 12:00 PM
Just my .02
Steve
yes I understand that........but I just was checking so I could get it close till I could afford it........the whole idea is I dont have loads of money.......so I will ball park it until I do have the money....I thought the toe was zero and a little bit of positive camber. but I just needed the toe for non shredding tires........its cool..you guys can drop 5 grand on big motors and other stuff, I am just tryin to get by with out damage to this or that.......just gonna string the toe and let it go........till I get the money to have it done right
Old 09-18-2006, 12:18 PM
Wiki Edits: 161
Sorry fumplet- I NEVER cut someone down for trying to do it themselves OR for having no money. Not intentionally, anyway.
I found out the same way as you that there is no accurate way for a guy with out an alignment rack to get all those suspension angles within spec.
You gotta do what you have to to get by.
later, mikey
Old 09-18-2006, 11:31 PM
yep I understand..............I just couldnt take the bottoming out and it was really bad.......mcdonalds entrance or any other drive way deposited the underside of the car.........freeway yielded bad wandering.......dangerous........well.........the vibration at 40 low rpm....has got better because of the front struts............and now I can feel the cause more.........when the car rpm drops the lowest.............low and behold the engine misses not steadily.....well now I can really feel it......not a steady miss.........but before the new struts, all I could feel was the front end oscillating sorta continuous..........soooooooowhen I have the money for the rear struts and get those put on..........its time to figure out or just scan it/scope it.......ask the crystal ball ect ........what evers best for the engine miss..........as it is one.............I ran the piss out of it the other day, got it real hot.........then I was able to tell in drive at a stop sign.....ah ha..........intermittent miss!!!........
Old 09-19-2006, 02:39 PM
Wiki Edits: 31
you could use a castor/ camber gauge for the castor/ camber adjustments. add 1/4* of extra positive camber to the left side to compensate for road crown. if you get camber wrong, it will pull the side with the most positive camber, if you get the castor wrong you can get a pull to a side if it's unequal, if it's wrong but equal you will not get steering wheel return to center, or return viloneltly. there is no way to check toe without a rack, the old tape measure between front and rear of tires back yard trick is way off, you won't have a pull, but within a week you'll need tires. not to mention checking the thrust angle. adjust camber, then castor and last toe. you will need a 4whl allignment if your rear end is fully indipendent, but I do happen to know that they are semi indipendent and would not have to have a 4whl allignment
1991 olds 88 coil pack check fumplet Engine 6 09-16-2006 08:12 AM
1991 olds 88 4L60 shudder?? fumplet Transmission - Rearend 4 09-11-2006 01:03 PM
1991 olds 88 injector cleaning fumplet Engine 19 09-09-2006 07:04 PM
1991 olds 88 heavy duty air conditioning fan polarity and position fumplet Electrical 3 08-30-2006 02:54 PM
1991 olds 88 front windows roll up very slowly fumplet Electrical 3 08-24-2006 01:10 PM
