I need ask Mustang II questions ( ID ) please - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2007, 01:22 PM
This is not a "don't you use a stock MII crossmember post"
I have some questions on the MII, I need help ID'ing the X-member
I need to ID the crossmember. I'm figuring I have a pre 74 Pinto with my luck. Is there some tall tale sign of what I have. I bought the cut out crossmember yesterday. I know I have the 13" wheels with the 4 lug discs.
I know I don't have the secondary strut mount corssmember. I do plan to build or find one.
If this is a pinto frontend, I read that the strut rods are different, should I find actual mustang II one before mounting and making strut mounts?
Also, Am I going to have to get different A Arms and spindles? anyhow to get
get 5lugs setup, was clear in my searches of the knowledge base.
Another thing is that I didn't get the stock swaybars, but was I was going to get
a bigger on anyhow.
ID:	19622   Click image for larger version
ID:	19623   Click image for larger version
ID:	19624   Click image for larger version
Old 03-19-2007, 03:14 PM
powerrodsmike's Avatar
Wiki Edits: 161
It looks like you have a 74 and up.
Telltale signs..
The early brakes have a cotter pin holding the retaining key, and the later calipers have flat head allen screws holding the retaining key. They also have a weirdly shaped bracket that surrounds the caliper that I don't see in your pics.
I don't think you could get a power rack before 74 either.
The later spindles you can put bigger brakes on without changing spindles. Speedway motors has everything you will need to get 5 lugs with stock roror size or you can go bigger ,(11"), brakes with ford or chevy bolt patterns.
I think the brake rotors thickness is another giveaway, with the early rotors being .750" thick, (minimum .690.) and the later ones are thicker, .870",( min.810")
I know the lower ball joints are different from pre/post 74 in the lower a arms, but I can't remember how.
Check the casting # on the spindle, IIRC it should have a D4 number on it somewhere.
Hope this helps,
Mikey
BE different....ACT normal.
Old 03-19-2007, 03:51 PM
aka Duke of URL
Yeah, the 71/73 PINTO was a different animal. FORD changed the sheet metal in 1974 and both platforms were the same (PINTO and MUST II). No PS until 1974.
Oh...I forgot as usual. You can use larger GRANADA rotors but please use FORD calipers and not DELCO-MORON...
Old 03-19-2007, 07:51 PM
I edited your thread title ... so you might would get
more views ...
Deuce ... Moderator
Old 03-19-2007, 08:24 PM
thanks for the info guys
I am taking more photos as I disassemble. I will also be cleaning up the frame parts that were left on this.
Old 03-19-2007, 08:30 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
Just curious...what are you going to install this on?
Old 03-19-2007, 09:11 PM
though I posted this
so it's going on a 64 fairlane wagon, the wagon has been chopped up at the frame rails this is how I got it a month ago.
going to rebuild the frame stubs and go from there.
you can see my 57 ford in the background.
Old 03-19-2007, 09:28 PM
Brian_B's Avatar
Lost in the 50s!
That looks relly straight for a 64. Start a journal of your buildup so we can all see.
Mustang II front shocks not "tall" enough BobbyG-39 Suspension - Brakes - Steering 8 08-10-2004 05:36 AM
Mustang II Home Alignment Ron M Suspension - Brakes - Steering 2 07-17-2004 11:08 PM
Mustang II pressure regulator Chev283 Suspension - Brakes - Steering 1 07-14-2004 02:13 PM
Mustang II bump steer, drifting Chev283 Suspension - Brakes - Steering 2 06-19-2004 08:15 PM
Mustang II Booster in a '49 Chevy Question hiimed Suspension - Brakes - Steering 4 03-11-2003 07:32 PM
