I need cam help
Hey i have a 355 sbc that i'm building for my '87 s-15. It has edelbrock performer rpm aluminum heads, performer rpm intake, wiseco flat top pistons, oliver rods, and a cam but the problem is i don't know what type of cam this is.. its markings are CWC 1579 and at the end of the shaft it has 413070. I suspect it might be a Crower?? but i'm not sure, i'm only 17 and don't have much experience with cams. it is hydraullic. I'm just wondering if anyone knows what type of cam this is, or if they have any suggestions on a good cam to use. Also, if any one has an idea of what it will make for power? i'm hoping it will be 400+ but if you have an idea please let me know, thanks.
This is from a prior post by member Bracketeer you can look it up,but here is what he said about the company CWC
"CWC Textron 1085 W. Sherman Blvd. Muskegon, MI 49441 U.S.A. CWC is the industry leader in ductile iron cams for passenger car and light truck applications. CWC ductile iron is specifically engineered for roller camshaft applications and is manufactured in high volumes according to exacting customer requirements and tightly controlled internal processes. Many customers also take advantage of CWC's innovative Flame / Cryo / Temper technology for pre-hardening of the camshaft lobes. By providing castings with the camshaft lobes already at final hardness prior to machining, customers are able to lower cost and capital investment while ensuring the highest quality and most durable product available in today's market." Maybe this will help some Cam kits from summit.com go for pretty cheep you should check that out to. Good Luck Last edited by TorkMonster400; 03-13-2008 at 12:16 AM. |
So does this mean that the cam is a roller cam? Ha yes the brakes and tranny have work to be done. The tranny shifts too soft so i'm told that it won't liekly stand the abuse, and it will have tons of abuse!
I just pulled this off of another website here is CWC's phone number I would call them if you still want the specs.
For more information about CWC camshafts call (231) 739-2610. I hope this helps in identifying your cam. |
CWC is the company that makes the raw cam core for 95% of all the cam companies that grind cams. CWC does not make finished camshafts, they just make the cam core ready for grinding the finished lobe on it. They sell the cores to other cam companies.
CWC makes the raw flat tappet camshaft core ready to grind for GM, Crane, Comp Isky, Lunati Federal Mogul ETCETCETC. If its a mass produced popular flat tappet cam CWC make the core for it. There is no point in phoning them. There are many production cam grinding companies that make "white box" generic replacement and generic high perf cams that don't stamp identifiable part numbers or grind numbers on the camshaft. many engie builders use these common genreric camshafts in their motors. This could even be a "custom grind" without meaningfull ID able numbers. If it is at all worn or the lifters are at all worn in any way, its not worth worrying about cause the cam and lifters are trash anyways. |
Oh OK i understand now thanks, so should i put in a comp cams extreme energy cam that i am able to get. it has 224-230 duration @ .50 and the lift is 502- 510. the cam would be free as i would trade for one of my hoodscoops. my only concern is would the idle be choppy with this sized cam? i'm using the truck to drive to school right now but i would really like to run low 13's or possibly a high 12. The truck is a 1987 gmc s15. the tranny is a 700R4 (auto) with a 2800 stall. rearend is a ford 9" with 355 gears. I've got 10 inch wide slicks and i'm not really sure what it weighs. I don't mind a choppy idle but i want it to be street able. If you have an idea of a time it might run i'd love to know thanks.
| Pontiac cam? | Wmarden | Engine | 12 | 08-22-2010 08:09 AM |
| Is it possible to degree an unknown cam? | Scrumgees | Engine | 4 | 03-18-2006 11:50 AM |
| 87 octane engine cam swap? | 71C10 | Engine | 6 | 01-20-2006 10:50 PM |
| Help Me Pick A Cam | Canadian Charlie | Engine | 2 | 11-16-2005 01:11 PM |
| More issues....lets talk cam failure | TurboS10 | Engine | 23 | 09-28-2004 11:51 AM |
