Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I need a carb spacer
Old 03-06-2012, 08:09 PM
Jake_Dragon's Avatar
Jake_Dragon Jake_Dragon is offline
Last journal entry: New Carb
Can you remove the carb and install the fuel line then bolt the carb back down?
Looks tight but you may have enough room.
But a 1/2 spacer wont hurt the carb, Jegs and Summit have a large selection.
I have aluminum spacers on my car and they work great, I sealed the bottom to the intake and just use a paper gasket between the carb and the spacer.
