I need a carb spacer - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2012, 04:01 PM
Last journal entry: 1978 Trans Am
Well, actually I do not want to use a carb spacer but when I tried to install my new carb feed lines I ran into a clearance issue (see attached pics) with the Performer intake. Btw, the feed lines are original parts from Quick Fuel for my SS-680-VS carb.
Anyway. A spacer is the only (easy) workaround I can think of right now. I guess a 0.5" spacer won't change the setup dramatically. Any recommendations for good ones or parts to avoid?
Thanks!
Old 03-06-2012, 06:45 PM
V305's Avatar
On the Border
Maybe you can tap the hole so the thread plug can go deeper
Old 03-06-2012, 08:10 PM
sqzbox's Avatar
My pipes are my music
Can you use a flexable line to the primary to raise the connection?
Old 03-06-2012, 09:09 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
Can you remove the carb and install the fuel line then bolt the carb back down?
Looks tight but you may have enough room.
But a 1/2 spacer wont hurt the carb, Jegs and Summit have a large selection.
I have aluminum spacers on my car and they work great, I sealed the bottom to the intake and just use a paper gasket between the carb and the spacer.
Old 03-06-2012, 10:20 PM
I had the same problem but with the manifold vacuum port behind the carb and had to use a spacer. I think someone else mentioned your best option, tap that plug a little deeper. What is it, maybe 1/2" pipe thread? Coat the tap with grease to collect the shavings and push it a little deeper and you may be good
Old 04-02-2012, 02:21 PM
Hi guys,
and first of all thanks for your suggestions.
I thought about tapping and I also thought about a carb spacer but finally a friend of mine (who knows a plumber...) offered his help.
He fabricated this -
It works!
Old 04-13-2012, 02:47 PM
while you're at it, you can do this, http://community-2.webtv.net/mattgru/carb/
Old 04-13-2012, 09:09 PM
1971BB427's Avatar
You could have saved some fittings by simply pulling that plug and grinding off the excess height that sticks up. It would still have plenty to hold the allen and tighten.
Best carb spacer style Edelbrock carb truckboy61 Engine 2 07-24-2011 10:18 AM
Which carb spacer? Greg T Engine 3 08-12-2010 07:40 AM
Will adding a 1 inch carb spacer affect carb tune? eric32 Engine 29 02-09-2010 01:13 AM
Carb Spacer juiced66malibu Engine 1 04-23-2007 07:21 AM
Carb install, spacer or no spacer? MM in NM Engine 3 03-17-2006 07:23 PM
