-   -   I need a chevy small block engine decoded (http://www.hotrodders.com/forum/i-need-chevy-small-block-engine-decoded-224544.html)
fordss 09-30-2012 10:54 PM
Block numbers is 3970010
Head numbers is 3870126
If you could decode this it'd be most appreciated. Thanks
Choctaw Bob 09-30-2012 11:42 PM
I have a Chevy Small Block Parts Interchange Manual by Ed Staffel, SA Design Books.
It shows this casting number was used for 3 different engines:
1. A 1969 302 with 4 bolt mains in a Z-28 Camaro
2: A 1969 327 with 2 bolt mains in trucks and industrial engines
3. A 1969 thru 1980 2 or 4 bolt main in most anything on the assembly line.
Head
The head number doesn't appear in my book.
DoubleVision 10-01-2012 03:06 AM
The 126 castings came on 327 and 350 engines from 1967 to 1970.
They have 1.94 intake and 1.50 exhaust valves. None of the sites list a chamber size for these heads however by looking at a picture they appear to be 74cc's. They likely don't have hardened exhaust seats and they also may not have accessory holes.
cdminter59 10-01-2012 03:42 AM
Chevy block ID
On 09/29/2012 at 04:43 pm, I gave all the infomation to ID this block in a thread titled Chevy Engine Module Number on page 2 of the engine section. Someone has moved the thread also.
cobalt327 10-01-2012 07:33 AM
All the engine ID threads get moved to the Basics forum.
For future reference, info on deciphering the castings, etc. of Chevy engines can be seen here.
Good luck.
fordss 10-01-2012 08:34 AM
ok thanks for all your help
cdminter59 10-01-2012 08:15 PM
Small block chevy engine decoded
block # 3970010 head 3870126 and k11 12 cnu ? don't know what that is thanks
K= St. Catherines, Ontario, McKinnon Industries, Canada.
11=November, 12= day of month. CNM= 1970 350 powerglide, 250hp, 2B carb, A= Chevelle, F= Camaro, X= Nova/ Belair/ Kingswood. 3970010 = 350 2/4 bolt mains, 1969-1979. 3970126 = 327,350, 1967-71, 1.94 intake 1.5 exhaust, The number 3870126 does not exist.
