I need an experienced engine builder/machinist help with a deck height problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2010, 05:18 PM
Im having an issue with piston deck height. The problem is the piston is not level across the piston pin.Number one and four are the worst,the front side of the piston is .012 out of the hole and the rear is .001 out. the other is .007 out and -.002 in. the others are wihin a few thou. The measurements were taken at center of piston across the pin.
Ive swapped them around to a different hole and even different rods and it seems to follow the piston but when I checked the pistons from the pin to the crown of the piston they are within .0005 tolerance.
This is a ford 302 stroked to 331 everything is new DSS Racing cnc'd block,eagle forged crank,eagle h-beam rods,DSS Racing Forged Pistons.
This isnt my first build and Ive never ran across something like this.
If anyone can help it would be very helpfull,If anyone can help id even call them to go into detail.
Scott
M&W Auto Custom Paint and Performance
Old 09-28-2010, 06:59 PM
Scott
The only thing you can do is have your rod and pistons ckecked using the alignment fixure sunnen has, You can check the piston on the rod and then check the rod for bend and twist with out the piston attached,
Good luck
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 08:31 PM
How Does A Thermostat Work? cobalt327 Hotrodding Basics 16 03-16-2010 06:32 AM
Knowledge base Dave57210 Hotrodders Site Suggestions and Help 2 12-20-2009 07:06 PM
18 HP go-cart engine problem oldred General Rodding Tech 20 05-10-2009 03:32 PM
New engine smoking problem MYKEEDIX Engine 4 08-27-2007 06:36 PM
