I need expert advise...plz
hunted down what I bought as a 62/63 corvette 327...my body man ran chkd numbrs in his book, my mechanic ran the numbers off of a website (GM). I have a dilemma...could someone knowledgable about chevy sm blks plz give me a definitive answer? My body man says its (the block) is a 307.....my mechanic says it is truly a 327.......the stamped (Raised) numbers on the top left if you were facing the motor in drivers seat, are as follows....3959512. HELP!
wrong forum...moving to engine
Ontario Rodders |
3959512....327...62-67...2...Was also used for some "CE" replacement blocks
http://www.mortec.com/castnum.htm Shane |
thanks 4x4chevy..
Thanks man....But I just found out that even tho that number, 3959512 is attached to a 62/63 327, that number does not tell you the engine displacement and other info....the inverted numbers stamped in the front are the ones that reveal everything you need to know...it is a series of numbers and letters that are stamped INTO (Inverted) the block, w/the last three bieng letters, that tell you displacement and where it was cast and other info.....I just saw on the GM site for smallblocks that the RAISED number could be anything from a 302 , 327, 207 to the 350 so the numbers on this block says its a 62 thru67 307
| Need some pontiac expert advise | ricksautorestoration | Hotrodding Basics | 15 | 06-02-2007 09:22 AM |
| Need some advise on ABS plastic repairs | USAF Chief | Body - Exterior | 1 | 11-01-2006 07:56 PM |
| Need advise. 01 Saturn SC1 tranny | 383MontecarloSS | Transmission - Rearend | 5 | 01-10-2006 05:01 PM |
| Advise need on building SBC | Pittbull | Engine | 6 | 11-28-2004 08:00 AM |
| DuPoint Problem Plz Advise | Aces0vr8s | Body - Exterior | 5 | 06-21-2004 11:04 PM |
