Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I need expert advise...plz
Old 02-28-2008, 09:45 PM
buttnakedo buttnakedo is offline
thanks 4x4chevy..
Thanks man....But I just found out that even tho that number, 3959512 is attached to a 62/63 327, that number does not tell you the engine displacement and other info....the inverted numbers stamped in the front are the ones that reveal everything you need to is a series of numbers and letters that are stamped INTO (Inverted) the block, w/the last three bieng letters, that tell you displacement and where it was cast and other info.....I just saw on the GM site for smallblocks that the RAISED number could be anything from a 302 , 327, 207 to the 350 so the numbers on this block says its a 62 thru67 307
