I need an expert opinion
I have a 68 mustang with a 289 that's been bored .030 over with forged internals all balanced, the deck has been trimmed down .01, Holley 570 street avenger, edelbrock rpm air gap intake, hooker super comp headers, a c4 with a Hughes 2200 stall converter and am in the process of putting a 3.40 gear in the rear end. I plan for this car to be a street strip car, something very street able but something I won't be ashamed of at the track.
70% street , 30% track The suspension is completely redone along with all new steering components. The real question starts now, what would be the best head and cam combo because what I have now is no where near matching each other or my stall. I want heads that'll fit with my intake and be in its powerband range and also fit my headers and I need a cam that will match with the heads and the stall I have. Right now the heads and cam don't match, the heads are over ported and leaving no velocity, the cam is a pbm can that I know nothing about othe than .498 lift, and the valves and rocker arms are stock. |
289 buzz bomb
The question here that begs to be asked is what kind of track time do you want to run?
The lower the ET the harder your gona havta buzz this short stroke little mill. |
Whats your budget look like? If its not a lot go pull a set of gt40 heads off of an exploder from the yard and have them rebuilt and throw in a roller cam to match the heads and intentions of the car. Otherwise there are plenty of aftermarket aluminum heads available for a sbf. |
I mean there's gotta be a way to go fast without overdrive I understand it won't be the fastest but I will build another motor to race. All my friends have cruiser motors and trannys and race motors and trannys and what ever they do they just switch out.
Ahhh how could I forget tr most important things. The only replacement for displacement. I bet this little motor would love some boost
figure out how fast you want to go first. Its hard to say okay i am gonna need x amount of hp because I want to go y speed. Have you raced cars before. Are you happy running low 14s maybe high 13s? If so you should be able to do it with the current bottom end you have. You just have to work on the top end. My buddy doesn't spin his motor over 6000 and is running good times for what it is. Like others have said if you really want to get that thing moving you are gonna need more cubes or maybe a power adder.
High 13s are fine right now until I do more but what is a good head and cam combo that will give me some good power. I don't mind turning this motor 6500 or so just don't wanna screw it up with this crappy cam and heads that are on right now.
210542-08 NA 258 264 230 236 .561 .574 108 104 .018 .018 1,16
1800-5600 Hot Street/Mild Strip. Good mid range torque & power. 2000+ stall. a cam like this or one or 2 sizes up or down,depending on your choice. 650 double pumper holley,good intake. rethink those 3.4 gears,maybe 4.3?up or down 1 ratio.13s in a small engine requires gears and RPM |
Go get some gt40 heads from an exploder. Do a google search on how to identify them and what years got them.
258 and 264 are the advertised intake and exhaust duration. 230/236 is duration @ 050 valve lift.
.561/.574 is the gross valve lift,not counting what you lose due to valve lash.108 is lobe ceparation angle and 104 is the intake love center line,,,.018 is the feeler guage size for valve lash,,1800 to 5600 is the RPM range of the cam |
for comparison
Advertised Duration (Int/Exh): 284/292 Duration @ .050 (Int/Exh): 241/249 Gross Valve Lift (Int/Exh): .525/.546 LSA/ICL: 110/106 Valve Lash (Int/Exh): Hyd/Hyd RPM Range: 2500-6600 similar on paper,,,but,,,very rough idle spend the extra money and get a small solid roller and have a nice idle and more power |
| The Following User Says Thank You to vinniekq2 For This Useful Post: | ||
Hookedup12 (08-08-2012) | ||
| Anyone an AC expert? | cal1320 | General Rodding Tech | 4 | 01-13-2011 05:44 PM |
| need some expert advice | atexaschevy4x4 | Hotrodding Basics | 6 | 09-23-2008 09:07 PM |
| I'm no expert, but.... | tfeverfred | Hotrodders' Lounge | 39 | 06-12-2007 07:43 AM |
| expert opinion please... | frankenstang57 | Transmission - Rearend | 3 | 05-26-2005 12:10 AM |
