I need a fabricator with a CNC bender - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2007, 08:00 PM
bg's Avatar
bg bg is offline
Looking for somebody to do some bending with a CNC bender. Would have to able to bend square stock in a 2D shape.
I need about 16 bars bent for a grille that is the contour of a 1948 Chevy truck original grille. The material would 6061-T6 or 7075 be about 1/2 inch tall and about 3/4 inch wide.
If any body knows where a bender can be found please let me know...
Bg
Old 10-08-2007, 09:52 PM
If you have a welder couldnt you just make a jig and bend it yourself?
Shane
Old 10-08-2007, 10:14 PM
bg's Avatar
bg bg is offline
I would think it would be very hard to reproduce consitant bends. One of the bends is a long slope bend which would be hard to bend...
Any ideas are welcome
BG
Name:	IMG_3118-1 (Large).JPG
Old 10-08-2007, 11:07 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
Did you check your local steel fabrication shops?
The one I used to work in has several press brakes. The newest one if computer controlled. I would not call it CNC exactly. Maybe NC would be more correct for it.
Anyway, it will make pretty much duplicate bends over and over once it is set.
I don't see why you can't bend it on a table with a torch if you set up a jig of some sort.
It would cost a fortune for the shop to do it for just 16 bars. Now..if you needed 1,600 or 16,000...then the cost would come down a lot per bar.
Old 10-09-2007, 08:33 PM
the profile on a piece of 2x12 (hardwood if available) rough out the shape with a jig or coping saw....sand it down to the desired profile.....take a rubber or deadblow hammer and beat it into shape
Shane
How To: Tubing Bender Twisted Minis Garage - Tools 65 11-18-2008 05:09 PM
CNC Parts, anything you would like to see? cold fusion Hotrodders' Lounge 8 02-16-2007 11:01 AM
CNC or NOT? oldsmo Engine 14 08-06-2005 07:34 PM
tubing bender Big Rig Garage - Tools 7 12-09-2004 09:17 AM
Pipe Bender Question silm man General Rodding Tech 17 11-21-2004 05:30 PM
