i need AN fitting help - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2006, 06:36 PM
Vortech 4.3's Avatar
jack of all trades
i have almost no AN fitting experience. assembled a few, thats it.
i am plumbing my new fuel injection setup. aluminum fuel rails, .500" ports.
what size fittings/line should i use, for the supply side, and the return side ?
i'm thinkin -8 for supply, and -6 for return ? i have an aeromotive regulator, that has 2 fittings on it, adaptor/AN on each side. i don't even know how to tell what size they are , but i think they are -8. they are the size i want for the supply .
i know this stuff is easy. but i have not delt with it enough to make it easy, yet.
thanx
Old 03-20-2006, 07:45 PM
41willys's Avatar
Blowin' it
Last journal entry: Running again...
Wiki Edits: 11
If you engine is not too radical. I would go with 6AN for supply and return.
Is this a small block?
Usually, I say usually, the ports on regulators are 3/8" npt, with is a 6AN. 8 AN works with 1/2" lines...
Jason
Old 03-20-2006, 07:52 PM
The number in the front of a AN fitting ( like 3AN ) is 1/16 th of a inch so.......a 3AN is a 3/16th inch line, a 6AN is 6/16th or reduced fractionally a 3/8ths inch line and a 8AN is 8/16th ( 1/2 ) inch line.
This should give you a better idea of what size you need....
Deuce...
Old 03-20-2006, 08:08 PM
jack of all trades
Jason
HP wise its not radical. but 500hp from a 4.3 is kind radical
but for this question, HP is the only factor. i think -6 is what i need.
what HP can -6 handle with domestic fuel injectors ?
thanx guys
Old 03-20-2006, 08:10 PM
jack of all trades
oh-yeah. i don't want pipe fittings on the rails. are there any issues with the O-ring type fittings ?
Old 03-21-2006, 06:26 AM
bondo's Avatar
That depend on How the Rail is Drilled,+ Tapped.........
The Threads,+ mating surfaces are Not the Same
Old 03-21-2006, 07:21 AM
41willys's Avatar
Blowin' it
Wiki Edits: 11
Using the NPT fittings into your pump, regulator, dist. blocks, and things like that will not affect your numbers. As long as you can supply the fuel with the correct pressures and volumes.
I do not know of any issues with o'ring fittings, but I have never used them either. I always use braided hose and AN fittings, and of course the NPT fittings in the pump, regulator and dist. block.
The NPT ports in the regulator, pump, and blocks are AN on the otherside. You just need the NPT into the ports.
Jason
"Basics of Basics" Trial fitting parts MARTINSR Body - Exterior 4 02-23-2008 09:33 AM
removing rusted out fitting dawg Engine 14 02-14-2005 04:42 PM
does anyone know of a 11/32 three way barb T fitting? Berliner Bel Air Engine 1 09-18-2004 05:32 PM
original 1936 ford gas tank fitting bomo General Rodding Tech 5 12-04-2003 04:20 PM
water pump fitting leaking brian400ex Engine 4 03-22-2003 05:06 AM
