i need to get beter fuel millage out of a chevy small block 305 stock - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2012, 11:10 PM
i have a stock small block 305 with a 600 cfm edelbrock carb i need help trying to figure out how to get better4 feul millage the most i can get is 11.5 miles to a gallon which i have been told by others is 1.5 miles more then a 305 should get if any one has any idea's or can help let me know
Old 06-22-2012, 12:22 AM
DoubleVision's Avatar
First off, is a adapter plate in use? Next how many miles are on it?
Third what is the timing set at.
What vehicle is it in and what is the rear gear ratio?
Old 06-22-2012, 05:58 AM
cool rockin daddy's Avatar
Put the two barrel that the factory put on these engines. Get a vacuum gage and train your foot to follow what the gauge says. This thing in a van?
Old 06-22-2012, 07:34 AM
Banned User
In my opinion, the first step when you're trying to improve mpg is to make sure you're calculating mpg correctly:
---verify that the odometer is tracking miles correctly. One way is to match it with highway markers.
---fillup at the same station AND and the same pump if possible. Fillup until it clicks Then divide miles driven by gallons you just pumped.
Example: 300 miles/10 gallons.
Old 06-22-2012, 10:19 AM
First, it's NOT stock, since you don't have the stock carb. Second, you didn't tell us the year or model. If this is a mid-80 305 that originally had the computer controlled Q-jet, a LOT needs to be done to convert to non-computer operation with good mileage. Third, if this is in a heavy vehicle, you won't get much better mileage with any engine. Give us a little more info to work with.
Old 06-23-2012, 01:32 PM
a 2v intake and carb, high performance ignition, free flow intake filter, new cat converter, headers, properly inflated tires, port work on exhaust, synthetic fluids..... all i could think of lol
Old 06-23-2012, 02:04 PM
Except what vehicle it's in.
Old 06-23-2012, 04:28 PM
bullheimer's Avatar
NEVER use credit cards!
try 7 mpg....HIGHWAY!!!
Old 06-23-2012, 05:55 PM
RWENUTS's Avatar
You forgot the EGG!!!
Drive like you've got an egg under the gas pedal!!!
Old 06-23-2012, 06:48 PM
LATECH's Avatar
X2 driving habits are the biggest thing when it comes to mileage.
Also condition of tune, plugs and timing, very critical
The carb, meh ... put a well tuned Small quadrajet non electronic carb on it.
Be sure you have a non computer distributor on it.
Your mileage will go up.some.
How many miles was a good question, a good tune cant help an engine with excess blow buy at the rings. To much is lost right there.
Need to do some preliminary checking on the situation. Dont just throw parts at it . Learn how to ID a problem and how to do basic tune up work.
Check it out first.
What kind of distributor does it have? Does the engine smoke?Does it have plenty of power as it is right now?
Fact is stranger than Fiction
Old 06-25-2012, 04:29 PM
1971BB427's Avatar
What tranny? Best thing you could do to improve mileage is an overdrive tranny. If it's a 3 speed auto, then find a 700R4 or 2004R and instll it. You'll get much better mileage on the highway.
Old 06-26-2012, 07:59 AM
boatbob2
Milage.........
What is the rear end ratio?? will have a LOT to do with milage....
Old 10-18-2015, 04:14 AM
What's your final gear drive ratio and which Trans are you using? I've found 4L60 non electronic overdrive (1990's) and A Good 1970's Rochecter Quadrajet (set up properly ) is the best recipe for Good or Better Mileage.Performs Great also if you know Quads well enough.Ive used them for years when others called them"Quadrajunk". Till I drove my Quad carbed small block Chevy Around them.
Old 10-18-2015, 05:23 PM
I gotcha beat! I get 8mpg in my pickup.
Old 10-18-2015, 05:27 PM
+1 to what's been said above.
Th' Ol ladys gut stock origional heavy *** '85 Pontiac Parisienne gets better than that wit' a 305, and 380000 miles on it. ('bout 30000 since overhaul)
It gets about 23 highway, and about 12-15 'round town.
max lift on stock chevy heads small block colton755 Engine 3 05-09-2011 04:27 PM
Need help wiring a chevy 305 small block?? seanwr30 Engine 9 03-16-2011 12:13 PM
305 small block chevy hp. stickshift Engine 18 04-08-2005 10:47 AM
1986 305 chevy vs. 1987 305 chevy new style small block mtinsley Engine 2 08-22-2003 11:55 AM
small block chevy to stock trans?? cajunone99 Transmission - Rearend 0 07-30-2002 10:52 AM
