i need help identifing my gm block - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2010, 11:30 PM
hello, i just baught a 81 eel camino to fix up and it has a chevy engine, but im not sure what engine it has. i have the numbers off the block, if anyone can help me, that would be great...GM 3932386 and block id 19J176917 V1209HH
thanks again
shaun
Old 12-03-2010, 01:19 AM
ericnova72's Avatar
More for Less Racer
Casting # 3932386 is a 4.000" block used to make 302, 327, and 350 engines in 1969. Can be either 2 or 4 bolt main, you will have to inspect it too know which it is. The "9" in 19J means installed in 1969 vehicle, the 176917 is the last 6 digits of the original vehicles VIN. "V"= Flint plant, "1209" is Dec 9th, "HH" is 350 cubic inch 300 hp 4 barrel w/ TH400 transmission, in a full size car(Caprice/Impala/Biscayne).
Old 12-03-2010, 06:32 PM
thanks so much for the info, now i can actually start working on it
GM small block 307 V8 rockthrower33 Hotrodding Basics 38 05-07-2010 06:46 AM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
1968-1969 olds 455 engine is this good and how can i id 1968olds455HO Engine 5 09-02-2009 11:53 AM
GM pressures CorvetteStripes.com over trademark issues Jon Hotrodders' Lounge 11 02-29-2008 04:04 AM
4.00 inch stroke crank in a stock gm 400 block sb72elcamino350 Engine 27 12-24-2006 11:17 AM
