I need help with a motorcycle headlight - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2004, 07:56 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Hey all you bike guys (the ones with fused spines, missing limbs, steel plates in your skulls, etc.), I need some info. I need to know what to look for in a 4 1/2" headlight assembly. I need to adapt it to a car project I am working on and should look like this,
a light with a chrome rim and some sort of mount behind. Any ideas?
Old 03-03-2004, 05:47 PM
Pony's Avatar
Willys 4 1/2" dia is the same size as the spot lights on all Harley dressers. They come clear, fluted, embossed halogen tri bar design, and a tri bar bullet center trim rings are available. They mount at the base with a single mounting stud. Check with any bike shop that deals with custom HD parts.
Old 03-05-2004, 02:58 PM
Ian70Mustang's Avatar
New Member
The older Yamaha FZR 600 had dual round headlights, no chrome but they use an h4/ 9003 bulb.
